My first Jabsco - SailNet Community
 3Likes
post #1 of 23 Old 08-03-2013 Thread Starter
Question My first Jabsco
I'm having my first experiences with a boat large enough to house a head (Catalina 25) and the neither the marina neighbors or the Jabsco manual hasn't been very helpful for my serious noob questions. How do I know when the tank has to be emptied? I'm going to do my first pump out this weekend and don't really know what to expect. Unlock the pipe and a machine does it? What sort of regular maintenance should I be doing (I've read about oil being flushed? Air fresheners?) And where exactly does the water come from for the flushing and do I need to fill this tank?
Thank you!
HaleyF is offline
post #2 of 23 Old 08-03-2013
overbored's Avatar
Re: My first Jabsco
the most fun part of boating. if you have a pump out fitting on the deck. you open it, put the suction hose on the fitting and the contents will be sucked out. there is no flushing, it is a vacuum device. that is it. close the cap before you smell the roses. how do you know when it need to be emptied empty? believe me you will know. I use Raritan K O and it works very well
Raritan Engineering | Cleaning and Maintenance Products/K.O. Kills Odors
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 23 Old 08-03-2013
Crealock 37
sailak's Avatar
Dock
Re: My first Jabsco
During routine use the toilet is usually "flushed" with seawater. There is probably a thru-hull and valve with hose to the toilet.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #4 of 23 Old 08-03-2013
Re: My first Jabsco
Find your holding tank. In same cases, you can actually open a cabin and see its level. In most, however, its under the sole and you'll really benefit from adding a level gauge. Over filling a tank can cause clogging (worst repair in marine history), smelly waste lines or even leaking at connections.
Emptying a holding tank is design specific. Some empty by gravity by opening a thru hull, others are pumped overboard by a macerating pump. All typically have a deck fitting to be pumped out by a marina, as most water are no-discharge-areas these days.
Jeanneau 54DS
Minnewaska is offline
post #5 of 23 Old 08-03-2013
Tartan 27' owner
CalebD's Avatar
Re: My first Jabsco
I 2nd the use of Raritan K.O. as a tank treatment.
It makes your effluent smell like cherries...
Everybody has one:
CalebD is offline
post #6 of 23 Old 08-04-2013
s/v Tiger Lily
dvuyxx's Avatar
Re: My first Jabsco
Ha! That reminds me of the other day ... I was cleaning our cat's litterbox while my 5 year-old observed. He looks at me with a sincere look on his face and says, "You know Daddy, this is the best part about cats!"
Admittedly, there is something grossly satisfying about hooking the vacuum pumpout hose to the boat and getting it done.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #7 of 23 Old 08-05-2013 Thread Starter
Re: My first Jabsco
Amazing! I'm definitely going to pick up some Raritan.
I didn't pump out this weekend because when I got back to the marina we had gusts of 16 kts. I didn't want to risk anything spilling anywhere haha. Thanks everyone!
jimgo likes this.
HaleyF is offline
post #8 of 23 Old 08-05-2013
Asleep at the wheel
jimgo's Avatar
Re: My first Jabsco
Thanks for asking this, I'm in the same situation!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #9 of 23 Old 08-05-2013 Thread Starter
Re: My first Jabsco
Totally gross question time! How easy do these tanks clog? If the tank is full can I leave it for a couple days or does it need to be emptied ASAP? Any tips for avoiding a clog?
HaleyF is offline
post #10 of 23 Old 08-05-2013
Old enough to know better
Re: My first Jabsco
Yes, and if your seawater tank needs to be filled you have a real problem!
Only necessary if your effluent does not already smell like roses like mine! I have not used K.O. but it seems to be the only additive that is not universally hated. I would say try it without additive (I never had a problem, but either I was very lucky or it really does smell like roses!) as you should not need one if the holding tank is appropriately designed. Big thing is ventilation and hoses. Most odor permeates from the hoses. Take a warm wet rag and run it along the hoses, if it smells like sewer, then you need new hoses. It would not hurt to run a bigger ventilation line to the holding tank, as you need air to keep the aerobic bacteria healthy and keep away the smelly anaerobic bacteria. Much the same as a septic tank at home.
Well the tanks normally don't clog, but he toilets and hoses do very easily. Normally it is too much paper or too think paper. There is a kind of flapper valve that is called the joker valve. Seems to be called a joker because the joke is on the owner who lets a visitor use the head! Biggest way of avoiding a clog is to use as little tp as possible, and flush with enough pumps and never ever put personal hygiene products in the toilet even it they say flush-able. Get it pumped before it is full, this helps as much as anything. Some people go so far as to say nothing goes into the head that you have not eaten first. They provide Ziploc baggies for toilet paper to go into. That takes it a bit far for me though. It seems to be common practice for long distance cruisers, and is often the case for land born sewer systems in some less developed areas of the world.
miatapaul is offline
Tags
jabsco
replacement for Jabsco??? tomnarciso Diesel 4 05-30-2012 07:26 PM
Jabsco housing leak Bay Gypsy Gear & Maintenance 20 01-04-2012 04:37 PM
waterpump replacement (jabsco) arne1981 Gear & Maintenance 2 04-26-2011 05:28 PM
Brydon Par Jabsco svey Gear & Maintenance 2 07-22-2008 09:37 AM
Jabsco Quiet Flush docket Gear & Maintenance 1 04-18-2004 08:32 PM
