rope clutch - SailNet Community
 1Likes
post #1 of 12 Old 08-04-2013 Thread Starter
rope clutch
My current rope clutch has ruined two halyards this year. I am upgrading to stay-set x 3/8, what rope clutch would be the best match for this line.
theperennial is offline
post #2 of 12 Old 08-04-2013
Re: rope clutch
No problems with my Garhauer clutch.
MarkSF is offline
The Following User Says Thank You to MarkSF For This Useful Post:
theperennial (08-04-2013)
post #3 of 12 Old 08-04-2013
Old as Dirt!
svHyLyte's Avatar
Re: rope clutch
Any clutch that uses a toothed cam to lock the line in place will damage the line unless pressure is taken off the cam before the locking lever is released. For that one typically needs a winch (or a good grip and strong forearms) to take a strain on the line. Several manufacturers use a wave action clutch (i.e. no teeth) that might be what you need if you don't have a means of taking a strain on the line before releasing the clutch.
FWIW...
MarkSF likes this.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
post #4 of 12 Old 08-05-2013
rhr1956's Avatar
Re: rope clutch
Garhauer
rhr1956 is offline
post #5 of 12 Old 08-05-2013
chucklesR's Avatar
Re: rope clutch
Actually, as much as I like my Garhauer's they were rated worst by Practical Sailor for line chewing.
I had no problems, 5 years in. YMMV.
However, if what you have has eaten TWO halyards in a single season even a bear trap would be better.
chucklesR is offline
post #6 of 12 Old 08-05-2013
I don't discuss my member
zz4gta's Avatar
Re: rope clutch
Different clutch would help. I really like my D1 lewmar clutches, but they aren't rated very high. Check on the D2's if you have a larger boat.
Taking the load on a winch before releasing is also good practice.
Another solution would be to add some additional cover to the halyard where it is clutched. Polytec, ARC, or MGP would all work.
Merit 25 # 764 "Audrey"
zz4gta is offline
The Following User Says Thank You to zz4gta For This Useful Post:
theperennial (08-05-2013)
post #7 of 12 Old 08-05-2013
Re: rope clutch
I used to have Lewmar clutches which are said to be the easiest on the line.
Unfortunately they also didn't seem to hold the line so well. (the newer versions are said to be greatly improved.)
Today I have Antals which seem to work relatively well at holding and not eating the line.
Apparently the most important thing is to have the right size line for the right size clutch,
Then of course, if you buy new halwards you can have them thickened, at the point where they enter the clutch.
Randy Browning
Norwalk, CT USA
sonosail is offline
The Following User Says Thank You to sonosail For This Useful Post:
post #8 of 12 Old 08-05-2013
Puget Sound Pounder
kellysails's Avatar
Re: rope clutch
I have recently seen an issue with my Spinlock clutch for the halyard. Once I get the main fully heaved up and tight, when I reduce pressure off the winch, about two inches of line sneaks past the clutch. Very irritating. I am going to clean the jaws with alcohol this coming weekend to see if that fixes the issue.
Has anyone seen this? This is a very recent issue.
kellysails is offline
post #9 of 12 Old 08-05-2013
zz4gta's Avatar
Re: rope clutch
This happens with all cam type clutches. It's jus how they're made. If the cams are sticking or worn it will be worse. We usually just grind up past our marks on the halyard, and let it settle after a couple tacks. Adjust if necessary.
Have you marked your halyard?
zz4gta is offline
post #10 of 12 Old 08-05-2013
Puget Sound Pounder
kellysails's Avatar
Re: rope clutch
That is a great idea. I have marks for reef points but I will add a new one for full sail. I do readjust after a few tacks and that gets it to where I want it to be.
Spinlock rope clutch repair rpeebles Gear & Maintenance 4 10-27-2011 03:14 PM
rope clutch handle replacement olgriz Gear & Maintenance 5 04-09-2010 06:08 PM
Help ID this Rope Clutch countdemonet Gear & Maintenance 7 07-15-2009 09:46 PM
Rope Clutch or Jam/Cam cleat for traveler? T37Chef Gear & Maintenance 13 03-26-2009 04:24 PM
Lewmare Super Lock or Spinlock XAS Rope Clutch? zz4gta Gear & Maintenance 6 08-19-2008 08:11 PM
