Winches, Anderson, Lewmar, Harken - SailNet Community
 2Likes
post #1 of 21 Old 08-05-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
I'm thinking of replacing my single speed non-ST winches with something a little better. To my mind the current Barients are underpowered, so I am looking at Lewmar ST30 (bronze/chrome rather than alloy), Anderson 28ST (full stainless) and the Harken ST40 (again in stainless).
If we assume they are all the same price, which would you go for, and why?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 21 Old 08-05-2013
mitiempo's Avatar
Re: Winches, Anderson, Lewmar, Harken
Anderson would be my choice. I have 40st's as main winches and 28st's on the cabintop, all Andersons.
Brian
mitiempo is offline
post #3 of 21 Old 08-05-2013
no longer reading SailNet
Alex W's Avatar
I have Lewmar ST30 (2 speed) on my Pearson and like them. Parts are easy to get and they are easy to service. I have no experience with Harken and Anderson winches.
With a 135% genoa I've sometimes wondered if ST40s would be a better size winch for my boat. It wouldn't feel much slower, and the extra oomph would be nice in high winds.
Alex W is offline
post #4 of 21 Old 08-05-2013
Senior Moment Member
SloopJonB's Avatar
Andersens, no question - even if they cost more - they are just about the nicest winches out there right now - bulletproof.
The only thing I'd like better would be plain (unchromed) bronze but that's only because I have a fairly funky looking boat.
SloopJonB is offline
post #5 of 21 Old 08-05-2013
Splashed
JomsViking's Avatar
Andersen anytime - saving to replace the existing Lewmar with Andersen.
They're a Little heavier than some of the 'composite' ones, but tougher, easier to service, has the best grip (so they feel bigger than the same size Harken/Lewmar), and they're easier on the sheets than anything else.
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #6 of 21 Old 08-05-2013 Thread Starter
OK, so sounds like Andersons might be the way to go. Comments on size? The 28ST is what Anderson recommend for the next size up boat (29-32ft) and seems to be the smallest 2speed ST they do.
Orange Crush
1974 C&C27 MkII
post #7 of 21 Old 08-05-2013
I don't discuss my member
zz4gta's Avatar
You need to compare the gear ratio's that you have now to the new ones. Only you can make that call.
And if weight and cost don't matter, than I'll vote Andersons as well. They'll last longer than you will.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #8 of 21 Old 08-05-2013
mitiempo's Avatar
My CS27 came to me with 28's as main sheet winches. I already owned a pair of 40's so I moved the 28's to the cabintop, replacing 2 old Lewmars and installed the 40's as jib sheet winches. 28's should be fine for a 27' boat.
Brian
mitiempo is offline
post #9 of 21 Old 08-05-2013
Do you really need 2 speeds on a 27ft boat?
I'm not being rhetorical, I am actually curious as we are replacing ours soon
Shinook is offline
post #10 of 21 Old 08-05-2013
jsaronson's Avatar
Lewmar 30s are overkill. Just sailed a Bene 39 that had them and they were adequate.
I rather have a slightly smaller 2 speed than a larger 1 speed.
jsaronson is offline
Harken VS Lewmar benesailor Gear & Maintenance 21 07-29-2013 01:32 AM
Installing new Harken radial winches Irunbird Gear & Maintenance 6 04-28-2012 12:42 PM
Anderson ST Winches and Regatta Braid jbondy Gear & Maintenance 0 10-14-2008 10:19 AM
Garhauer, Harken, Lewmar & Schaefer sanctuarysam Gear & Maintenance 17 11-02-2006 09:38 PM
lewmar winches shmangasarian Gear & Maintenance 0 11-01-2005 04:48 AM
