Waste deck fitting stuck - SailNet Community
post #1 of 10 Old 08-05-2013 Thread Starter
jsaronson's Avatar
Went to have the holding tank pumped out for the first time in about 9 months. The fitting and cap are 30 year old aluminum. I have a good bronze spanner wrench but the cap would not budge. I sprayed it with PB Blaster and will try again. Other than adding length to the handle for more leverage, any suggestions?
jsaronson is offline
post #2 of 10 Old 08-05-2013
Asleep at the wheel
jimgo's Avatar
Re: Waste deck fitting stuck
Was it a hot day? Wondering if the metal could have expanded.
I wonder if something like the equivalent of an impact driver could work; that is, hold the cap under tension with the wrench and (gently but firmly) hit the cap (not the wrench) to try to break it free.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 10 Old 08-05-2013
fryewe's Avatar
Pour vinegar on the cap making sure it gets into the threaded area then put a rag soaked in vinegar on top of the cap and leave it there for a few hours. Then try to remove it. If no joy then soak longer and try again. The vinegar will eventually get soaked into the joint and break up the corrosion.
Good luck.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #4 of 10 Old 08-05-2013 Thread Starter
jsaronson's Avatar
It was sunny but not hot. Vinegar sounds like a possibility! I was thinking that worst case I could drill 2 holes in the cap where the wrench goes, insert bolts and use a breaker bar. I rather not go there!
post #5 of 10 Old 08-05-2013
azguy's Avatar
The PB blaster will work it sometimes just takes a 2-14 hrs with repeated soakings.
azguy is offline
post #6 of 10 Old 08-05-2013
Assuming you ever do get the cap open (PBlaster and patience damn well ought to do it) put a little silicon grease or TefGel on the threads when you put it back on. If you don't have at least one tube in each toolbox, this is the time to pick some up.
hellosailor is offline
post #7 of 10 Old 08-05-2013
Tim R.'s Avatar
Worse case is you replace the entire deck fitting with an all stainless one. You should probably do this anyhow. If you are in salt water, this will continue to give you problems.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #8 of 10 Old 08-05-2013
My very Neanderthal approach to these situations, after using the PB Blaster, is to smack the handle of the wrench with a fairly heavy hammer and hope the impact force will produce the desired results.
Seaduction is offline
post #9 of 10 Old 08-05-2013
S/V Lilo, Islander 32
Just remember the other half of the deck fitting is attached to the deck. To much force and you could turn the whole thing instead of just the cap. PB Blaster, Vinegar, light tapping on the cap itself aught to open it up. If not, depending on how it's installed it might be better to just replace it rather then apply too much force and tear mounting screws or something out of the deck, or doing other damage based on how it's installed.
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #10 of 10 Old 08-05-2013
Barquito
Barquito's Avatar
Breaker bar, and lots of swearing.
Valiant 32
Barquito is offline
Tags
deck fill , waste
Broken brass/bronze fitting. I'm stuck... RobGallagher Gear & Maintenance 22 08-12-2012 07:38 PM
Name that deck fitting extremo Gear & Maintenance 7 04-22-2012 01:51 PM
Deck Waste Caps Jolubrle Gear & Maintenance 10 05-25-2011 05:33 PM
Waste deck fitting cvsheppard Pacific Seacraft 2 07-28-2010 06:39 PM
Stuck Waste Cap cpr66 Gear & Maintenance 4 08-19-2007 01:19 PM
