how to adjust jib leads on toe rail - SailNet Community
post #1 of 12 Old 08-05-2013 Thread Starter
I sail a Mariner 28 and I have to put the jib leads on the toe rail in order to get the desired sail shape.
I use snatch blocks on the toe rail. This is a pain to adjust. I was in strong winds yesterday and really needed to adjust these block back further but there is no easy way to do this while the sail is under load.
Any one in a similar situation who got more creative and solved this issue?
1979 Mariner 28
Sailing out of Herrington Harbor North
Deale, MD
andrewoliv is offline
post #2 of 12 Old 08-05-2013
Barquito
Barquito's Avatar
Re: how to adjust jib leads on toe rail
May not be efficient, but, you can tack, adjust the block, then tack back. Or, also not really easy, you could keep going, tie another sheet onto the headsail, put another block on further back, (grab the one from the windward rail), run it through, cleat it off, and finally take the original off. Final idea: If the jib does not hoist the full length of the forestay, you could change the lead angle by changing how high the jib is hoisted.
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is online now
post #3 of 12 Old 08-05-2013
4KSB driver.
You could always use a barber hauler.
***Boatless
**** Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #4 of 12 Old 08-06-2013
Remember you're a womble
PaulinVictoria's Avatar
Head up to relieve the pressure on the sheet, adjust, head back down. Or if there are a few of you onboard, you can step on the sheet ahead of the block whilst someone moves it depending on how heavy the wind is.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 12 Old 08-06-2013 Thread Starter
I have been heading upwind and adjusting. Was hoping there was some magical piece of hardware. A barber hauler may be an option.
1979 Mariner 28
Deale, MD
post #6 of 12 Old 08-06-2013
Old as Dirt!
svHyLyte's Avatar
Take a short piece of 3/8" line, tie a rolling hitch around the sheet fwd of your block, and tie the line to your toe-rail with a slipped cow-hitch. Ease your sheet at the winch which will transfer the sheet load to the temporary tether and relocate your block. Slip the cow-hitch and you're done. The foregoing takes more time to describe than to do.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
andrewoliv (08-06-2013)
post #7 of 12 Old 08-06-2013 Thread Starter
like that idea!!
1979 Mariner 28
Deale, MD
post #8 of 12 Old 08-06-2013
I've actually been working on this exact problem because my 28' S2 works exactly the same way.
What I am making is a U-bolt in a piece of G10 made to slide along the toe rail and lock into the notches. The sliding surface will be teflon. The trick is making it "universal" for various types of toe rails. Not sure when it will be available for sale thru Gulf marine Technologies.
Frogwatch is offline
post #9 of 12 Old 08-06-2013
I don't discuss my member
zz4gta's Avatar
Merit 25 # 764 "Audrey"
zz4gta is offline
post #10 of 12 Old 08-06-2013 Thread Starter
The above drawing doesnt work. I have tracks installed there and they are too "inside" for the size jib I fly (135). I have had to remove the jib sheet from the track and attach to a snap block on the toe rail.
1979 Mariner 28
Deale, MD
Adjust rigging on AMF/Alcort Trac 14 jromeski Gear & Maintenance 3 02-03-2014 08:53 PM
Now Blow (how to adjust compass) Me Down HighFly_27 Gear & Maintenance 5 11-12-2012 09:42 AM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 10:28 AM
AROUND JAPAN/UOZU, Toyama Prefecture: 300-year-old fishing festival changes its dates to adjust to the changing times (Asahi.com) NewsReader News Feeds 0 02-05-2007 10:15 PM
