Rub Rail or Body Work? - SailNet Community
post #1 of 10 Old 08-06-2013 Thread Starter
My new (1980) Apollo 16 has a place where the hull is separating from the deck. It appears that a previous owner tried to repair it with some form of sealant.
I've read about various repairs, the most logical being to dig out as much of the old material as possible and use an epoxy with fiberglass particles BUT I have no experience with that and somehow I came up with the idea of possibly installing some form of rub rail.
I think I would be more comfortable installing a rub rail plus, I have had the boat out just twice and since the boat was designed for speed, it bounces all over the place at the staging dock, so I'm thinking a rub rail might also prevent damage.
Am I thinking right? Is this a logical step to take or should I suck it up and learn to do body work? Here's a pic of the seam...
TBApollo is offline
post #2 of 10 Old 08-06-2013
manatee's Avatar
Re: Rub Rail or Body Work?
Do both? A good backing plate & rail for mechanical strength, with [5200/epoxy putty/$goop] for sealant.
Was this on the pre-purchase survey? I think *someone* owes you a partial refund if you were not aware of it.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #3 of 10 Old 08-06-2013
azguy's Avatar
I bet no survey was done.....
azguy is offline
post #4 of 10 Old 08-06-2013
Tartan 27' owner
CalebD's Avatar
Who surveys a 16' dinghy?
Epoxy is pretty easy to work with once you learn how.
No time like the present.
Everybody has one:
CalebD is online now
post #5 of 10 Old 08-07-2013 Thread Starter
Nope, no survey--30 yr old dinghy with a few fixable issues. It seems like doing both might be a good idea. I have to wonder though, if drilling holes will negatively effect the integrity of the structure (at least that is how I understand rub rails are installed). The reason I wonder is that I don't see dinghies with factory installed rub rails.
From searching, it looks like the best product to fix the gap would be those from West System, mixed to the consistency of peanut butter. Any other thoughts on products?
TBApollo is offline
post #6 of 10 Old 08-07-2013
Tartan 27' owner
CalebD's Avatar
Sounds to me as though you are heading the right direction for this repair.
The West System use guides is a great resource for helping you learn to use epoxy.
WEST SYSTEM | Use Guides
Yes, there are other brands of epoxy that may be cheaper (Mas, System 3 etc) but for the amount of work you need to do and West's great customer support it is well worth using for a first time around the block with epoxy.
Have you found a rubber rub rail to go over the hull/deck joint?
Everybody has one:
post #7 of 10 Old 08-07-2013
rhr1956's Avatar
Maybe just flip the boat upside down, grind and dig as much of the bad stuff as you can. Separate the hull and deck just enough to pack / inject epoxy and chopped glass into the void and clamp it tight till the next day. I'm thinking a two hour job at most. No need for rub rails and stuff. It's a 300 lb boat. Let it bounce and bang...it won't kill it.
rhr1956 is offline
post #8 of 10 Old 08-07-2013 Thread Starter
CalebD, no rub rail choice yet. I'm a sailing noob and not too familiar with what's available and best for my application. After RHR's post above, I'm thinking I may just do the body work and then see how it goes.
I've only had the boat out twice and both times it just seemed logical to have a "bumper" at the staging dock but really, the boat is so unstable I plan to be around docks as little as possible and beach it instead.
RHR, will it be best to flip it over in order for the epoxy to set up right or will that just make the job easier?
TBApollo is offline
post #9 of 10 Old 08-07-2013
rhr1956's Avatar
Flip it over so you can work standing up. Also it will allow the resin to flow down and into the void.
rhr1956 is offline
post #10 of 10 Old 08-07-2013
You've only sailed the boat twice, it's lasted 30 years as is, why not sail it enough to see if this is a problem worth your valuable time to repair?
You may have a couple more spots of "dock rash" to repair before you become the perfect sailor anyway.
capttb is offline
Open Body vs. Closed Body turnbuckles? labatt Gear & Maintenance 6 04-15-2011 09:59 AM
Anybody need an able body for racing? dylanthered Pacific Northwest & Alaska 2 08-12-2009 09:40 AM
New Bow Rail josdif Irwin 3 05-16-2009 09:07 AM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
