new wood and varnish ??? - Page 2 - SailNet Community
 5Likes
post #11 of 44 Old 08-08-2013 Thread Starter
Re: new wood and varnish ???
and the epifanes needs to be thinned a tad?
abrahamx is offline
post #12 of 44 Old 08-08-2013
Asleep at the wheel
jimgo's Avatar
Epifanes has a recommended application technique on the can. You start off thinning it something like 50/50 with mineral spirits, then gradually work your way up to non-thinned. I think the thinned version did a really nice job of self-leveling, which meant less work. I used Rustoleum this time on my hatch boards (didn't have time to order Epiphanes, and couldn't find it locally), and should have thinned the first few coats. I would have gotten a much better finish. I'm OK with my results given the time pressures I had, but I think a thinned version would have been better.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #13 of 44 Old 08-08-2013
I'd agree with that, apart from the ending at non-thinned. I find 10% thinner helps in several ways - it goes on better, you get a smoother finish, and it dries more quickly so there's less chance of wrinkling.
To meet VOC standards all varnishes and paints are really thick as supplied, these days - you pretty much have to thin anything before use.
MarkSF is offline
The Following User Says Thank You to MarkSF For This Useful Post:
abrahamx (08-08-2013)
post #14 of 44 Old 08-08-2013
poopdeckpappy's Avatar
I think your biggest maintenance problem regardless of finish will be be the woods themselve, especially the fir due to the moisture in the wood. If it does eventually dry, it will split as will the oak unless, the oak is white and both KD'ed, even still the fir my go moldy on ya under the finish
Keep an eye on them
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #15 of 44 Old 08-08-2013
Asleep at the wheel
jimgo's Avatar
Pappy, how long do you think it will take for the fir to go moldy, especially if he puts covers on them?
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #16 of 44 Old 08-08-2013
Before his first annual maintenance, especially if covered but, if it was Kd wood, it will last a wee bit longer
1974 Ranger 33
post #17 of 44 Old 08-08-2013
Tartan 27' owner
CalebD's Avatar
You will find out soon enough why Teak and Mahogany are usually used on boats.
Use what you've got though and report back in a year or two.
Sabreman likes this.
Everybody has one:
CalebD is offline
post #18 of 44 Old 08-08-2013 Thread Starter
Yep, thats why I half regret getting him involved. He was talking mahogany and next thing I know he has everything done in fir. Then switched to oak, which is good, but I specifically asked/told him I wanted everything to match.
abrahamx is offline
post #19 of 44 Old 08-08-2013
Well go with for now, don't hurt any feelings
1974 Ranger 33
post #20 of 44 Old 08-08-2013 Thread Starter
Yep. I'm not using 5200 to bed it though like he is suggesting.
ottos and jimgo like this.
abrahamx is offline
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 28 05-15-2014 09:21 PM
Varnish stiffwind Gear & Maintenance 1 04-12-2011 11:20 PM
Exterior wood: Urethane vs. Varnish Dcneuro Gear & Maintenance 1 03-08-2009 07:24 PM
Best wood-to-wood adhesive kwaltersmi Gear & Maintenance 16 10-27-2007 07:25 PM
Varnish? Ronbye Gear & Maintenance 34 07-15-2006 12:41 AM
