new wood and varnish ??? - SailNet Community
 5Likes
post #1 of 44 Old 08-08-2013 Thread Starter
My step dad remade all the wood handrails, winch island, etc.. All wood up top. I let him do it at my hesitation cuz he gets ahead of me an tends to just do things his way. anyway, they are done and ready to install. He stained and put one coat of helmsman spar urethane on it. Just wondering what you guys think about this product? Can I go over it with something better? He also says to use steel wool inbetween coatings? I always thought steel wool was a no no on a boat? Opinions please.
abrahamx is offline
post #2 of 44 Old 08-08-2013
pauloman's Avatar
Re: new wood and varnish ???
I would put about 4 coats of tradtional spar varnish over his one 'base' coat
Paul Oman - MS. MBA
A.K.A. “Professor E. Poxy”
Internet Epoxy Confederation (IEC) Homepage
epoxies since 1994
Member: NACE (National Assoc. of Corrosion Engineers) -- SSPC (Soc. of Protective Coatings)
epoxy supplier
pauloman is offline
post #3 of 44 Old 08-08-2013 Thread Starter
any brand recomendations
abrahamx is offline
post #4 of 44 Old 08-08-2013
I use Pettit 2015 Flagship varnish. I've also heard that Epifanes Wood Finish is pretty good.
You need at least 4 coats, and preferably 7 or 8. It is too thick as supplied so you'll need the matching thinner.
The best maintenance regime is a top-up coat, once a year. Sand lightly, and apply one or two coats, slightly thinned.
You are right about not used steel wire wool on a boat, they sell copper wire wool at the chandlers. However, I always use 320 grit sandpaper between coats.
MarkSF is offline
post #5 of 44 Old 08-08-2013
What kind of wood did he use? Teak is nice but doesn't hold varnish very well. If it is teak, the first coat should have been thinned with thinner 50/50 to really soak into the wood. If it is teak, you probably need more than 4 additional coats, maybe 6-7 and yes, do not use steel wool - use very fine sand paper and a tack cloth to get all the dust off between coats.
Catalina 34
chuck53 is offline
post #6 of 44 Old 08-08-2013 Thread Starter
He used fir for the rails and oak for the winch islands and new block to level the winch. Not my choice but free to me so I wont complain even though I would like to.
abrahamx is offline
post #7 of 44 Old 08-08-2013
Asleep at the wheel
jimgo's Avatar
The Helmsman should be fine. Epifanes seems to be the "preferred" varnish, but for your purposes the Helmsman should be OK. If you have, or can make, UV covers for the wood, the Helmsman should last quite a while.
As for the steel wool, that's somewhat "old school", but it works. There are Scochbrite-style pads that do the same basic thing as steel wool, but don't leave steel splinters in the wood/finish that might oxidize and rust. As I understand it, that's part of why steel wool isn't really used on boats - it can rust too easily.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 44 Old 08-08-2013
Asleep at the wheel
jimgo's Avatar
I don't think there's much of a reason to complain. The fir might be a bit soft, but as you said, it's free. If he used white oak for the blocks, you'll be in good shape, that's a very "outdoor-friendly" wood.
Worst case, you can re-do everything to your liking in a few years when it goes bad. In the meantime, though, he's allowed you to focus on other "stuff" that needs to be done, which is great, IMHO. I'd like someone to do some of the work for my boat!
abrahamx likes this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #9 of 44 Old 08-08-2013
Barquito
Barquito's Avatar
I second Epifanes. The high tung oil content keeps the product more flexible. The West Marine brand is probably similar, but costs less.
Valiant 32
Barquito is offline
post #10 of 44 Old 08-08-2013
Sabreman's Avatar
Helmsman is fine, I've used it extensively. 10 coats on all sides. Sand between coats with 220 or 320. But you are setting yourself up for a lot of maintenance regardless of brand. The finish must be maintained or will lift rapidly.
Oak is especially vulnerable to black streaks if not well sealed, due to tannins in water.
bljones likes this.
Sabre 38 "Victoria"
Sabreman is offline
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 28 05-15-2014 09:21 PM
Varnish stiffwind Gear & Maintenance 1 04-12-2011 11:20 PM
Exterior wood: Urethane vs. Varnish Dcneuro Gear & Maintenance 1 03-08-2009 07:24 PM
Best wood-to-wood adhesive kwaltersmi Gear & Maintenance 16 10-27-2007 07:25 PM
Varnish? Ronbye Gear & Maintenance 34 07-15-2006 12:41 AM
