Hatch Latch - SailNet Community
post #1 of 2 Old 08-09-2013 Thread Starter
Hatch Latch
Annie has the usual barrel latch on the sliding hatch to the companionway. And when the washboards are in place, of course, the barrel latch can only be operated from below. I've seen passing references to latches that can be operated from either inside or outside. Anyone familiar with such a piece of hardware? Would it be something homebuilt or is there a commercial solution. Greatly appreciate any info.
s/v Annie
PSC 37
Time Traveler is offline
post #2 of 2 Old 08-09-2013
Re: Hatch Latch
There was a thread on this over at SA recently, as it is a requirement for certain offshore races. My favorite solution was a spring loaded latch mounted vertically on the inside of the top hatch board and that had a cord attached to it that was fed out through the vent slots, thus allowing you to operate it from outside.
Plumbean is offline
Islander 30 Bahama latch huguley3 Islander 4 06-09-2010 07:04 AM
Teak enclosure - latch recommendations needed josrulz Gear & Maintenance 14 03-19-2010 05:53 PM
"Hatch Latch" PalmettoSailor Gear & Maintenance 2 09-15-2009 07:39 PM
Need new latch cover!? Lesmusic1 Newport 3 11-03-2007 09:08 PM
Pacific Seacraft door latch KenD Gear & Maintenance 1 01-18-2007 02:06 PM
