08-23-2004
Crazying and Soft Spots on Deck
Hi GarrettK,
I have a 1972 Gulfstar 43MS center cockpit and it has its share of leaks, soft spots, crazing and hull delamination but, it''s all doable. Crazing or stress cracks occur on all boats and especially on older boats. They are generally superficial hair line cracks in the gel coat. If they are larger than hairline, they enter into the realm of stress fractures and they will definately let water into the sub-structures (typically balsa, plywood, or a combination of the two) and this is what causes your "soft spots". You are literally standing on the gel coat and fiberglass pressing down into the area that once held the firm sub-structure materials. Now it''s either water soaked mush or rotted material that gives under your weight. There are many ways to repair the damage, ranging from drilling holes and drying the area with a heat gun and filling the vacated area with a special resin to cutting away the damaged area and replacing the materials with new sub-structure material and re-glassing. I''m a do-it-yourselfer and I started with the small projects like re-bedding the stantions, cleats, and portals. At the end of this season, I will start to tackle the larger areas and try my hand at replacing the damaged areas of my deck (soft spots). There are any number of books on the subject. One of my favorite series is by Don Casey. His books are full of illustrations and helpful instructions and "Sailboat Hull and Deck Repair" would be right up your alley. Hope this helps
