Use of moisture meter - SailNet Community
post #1 of 2 Old 08-10-2013 Thread Starter
davidpm's Avatar
I have had one of the electrophysics ct33 meters as recommended on this forum for several years. I only use it on the deck and am pretty sure that if the meter shows wet near a stanchion and dry a couple feet away it is giving me some solid information.
I have never used it below the water line because of the copper in the paint.
Recently I saw someone use it on a wood sole. There was some obvious water damage near the edge of the sole. The meter showed wet near the edge and dryer near the middle.
Would you consider this real information. I worried about picking up a wire or other metal near the edge of the sole.
davidpm is offline
post #2 of 2 Old 08-11-2013
JimsCAL's Avatar
Re: Use of moisture meter
Since measuring the moisture content of wood is one of the common uses for these meters, use on the sole would seem to be fine. Errors caused by nearby metal are always a concern with the pinless meters.
JimsCAL is offline
Is there an affordable moisture meter? jarcher Gear & Maintenance 19 1 Day Ago 04:05 PM
Which moisture meter would you recommend? MarkSF Electronics 2 03-31-2013 04:20 AM
HELP! - Need Moisture Meter in Ft Myers eherlihy Boat Review and Purchase Forum 0 02-24-2010 05:37 PM
Could someone lend me a moisture meter? TakeFive Gear & Maintenance 24 12-25-2009 12:36 PM
Could I borrow a moisture meter? TakeFive Boat Review and Purchase Forum 1 12-21-2009 08:48 AM
