Yanmar still overheating - Page 3 - SailNet Community
 3Likes
post #21 of 37 Old 08-14-2013
Tim R.'s Avatar
Re: Yanmar still overheating
If you are going to drain the coolant then you should remove the heat exchanger core and check it. It is not hard to do especially if the coolant is already drained.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #22 of 37 Old 08-14-2013
Crazy Woman Boat Driver
Melrna's Avatar
Location: Heading south down the US east coast to the Bahamas
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
I had the same problem on my engine. First, check to see if your water manifold was recalled. See previous post on this one. Mine was and Yanmar changed it out free. The grey smoke can be caused by a plugged up exhaust elbow. The 3YM30 engines Yanmar recommends every 250 hours to clean it out or replace it.
Take off the hose and shine a light up the elbow to see if it is plugged. If so take off the 4 bolts that hold the whole unit on. You will not be able to unscrew the elbow from the adapter while on the boat. Go the easy route. Either get it cleaned or replace it.
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
post #23 of 37 Old 08-14-2013 Thread Starter
THEFRENCHA's Avatar
Thanks Melrna Did that last month ! Perfectly clean now with good water flow
THEFRENCHA is offline
post #24 of 37 Old 08-14-2013 Thread Starter
THEFRENCHA's Avatar
Agreed but will I be able to save the gasket or should I order one new before removing heat exchanger.??
post #25 of 37 Old 08-15-2013
captflood's Avatar
GREETINGS EARTHLINGS; If the problen still persits WHEN DID YOU LAST HAVE THE INJECTORS CHECKED this could be the cause, THIS happens the same on big waggon engines and boats Donks or mainly a dirivitive of them AS ALWAYS GO SAFE.
shanedennis likes this.
captflood is offline
post #26 of 37 Old 08-15-2013
Tim R.'s Avatar
Not sure about yours but on my 4jh2e the gasket is simply a reusable O-ring. Order new as you should have some spares on hand anyway.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #27 of 37 Old 08-21-2013
cjb
French - how did it turn out? are you back up and running?
cjb is offline
post #28 of 37 Old 08-22-2013 Thread Starter
THEFRENCHA's Avatar
Finally was able to work on engine yesterday
Found oil in the bilge ! Dipstick showed half empty But was full last week when we started our trip
Refilled and started the engine . I have a mist of oil coming out of engine !
Right about 2 inches after the oil filter and below the fuel pump At first looked like I was missing a bolt on the engine block No kidding !
Then found this part in the bilge
photo.jpg Photo by THEFRENCHA | Photobucket
Fits right in, and stops the oil leak but what is it ? Its a plastic plug with a small metal tube inserted Could be that I am still missing a piece ?
It is not a sender or pressure sensor Nothing can be connected to it
Could it be a pressure overflow ? Then I would be probably missing a plastic tube on top that would guide overflow of oil into the bilge
I emailed the pict to Yanmar but yet no answers Local parts dealer has no clue
Scratching my head
post #29 of 37 Old 08-22-2013
Is your engine a sail drive version?
http://tehstar.ru/assets/files/manuals/3YM30.pdf
aa3jy is offline
post #30 of 37 Old 08-22-2013
overbored's Avatar
Dip stick plug, there are different models with the dipstick in a different location and that hole is not used and plugged. although your piece looks more like a cut off dipstick. is the piece in the center solid or hollow tube
"GOLD RUSH" PRINDLE 16
overbored is offline
Yanmar 3GMF Overheating gordofloats Diesel 20 05-23-2012 12:13 PM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 02:40 PM
Yanmar 2 qm 15 overheating mystery NickAllinson Gear & Maintenance 9 06-26-2011 10:39 PM
Yanmar 3HN35F OVERHEATING kjango Gear & Maintenance 11 05-26-2009 10:29 PM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
