Yanmar still overheating - Page 4 - SailNet Community
 3Likes
post #31 of 37 Old 08-22-2013 Thread Starter
THEFRENCHA's Avatar
Re: Yanmar still overheating
Yes it is a plug but not for a potential dipstick !
How it popped off is quite a mystery and the consequences could have been really bad considering how much oil comes gushing out!
All my thanks to Niemiec marine . They did not know but made a few calls to Yanmar and came back with the answer.
Plug for a potential additional sensor The recommendation is simply to re insert, maybe with a tiny bit of caulk to make sure it does not come off
The good news is that I do not need to buy anything
THEFRENCHA is offline
post #32 of 37 Old 08-22-2013
Brewgyver's Avatar
I would be concerned about WHY it popped out. Is it a cause, or a symptom? With a recent oil change, there's the possibility that it was over-filled. If it pops out again, you could have a bigger problem (piston rings, e.g.)
I doubt most caulks would do a good job of holding it in place, might be better off using safety wire.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #33 of 37 Old 08-22-2013 Thread Starter
THEFRENCHA's Avatar
Same concern Will just re insert with nothing additional to hold it And then keep an eye on it. I think that when engine overheated ...oil came very hot and maybe expanded ? Or just the heat created vapors inside engine ?
Yanmar says its does not mean anything bad ....unless it pops out again without the overheat... Engine run smooth and no smoke of ant color so ...sea trial next Saturday
post #34 of 37 Old 08-24-2013
Brewgyver's Avatar
Frencha, could have been blow-by, in which case it will happen again, and you'll neet a ring job, at least. Hope it's not!
From pouring over the Yanmar engine parts drawings, it doesn't appear to have a crankcase vent, so, like you said, it could simply have been caused by the overheating, so you're back to that. Look forward to a report on your sea trial!
s/v My Sweet Girl!
Atomic 4
post #35 of 37 Old 08-24-2013
overbored's Avatar
all Internal combustion engines have a Crankcase vent. The vent on the Yanmar it is in the valve cover as it is on most engines
"GOLD RUSH" PRINDLE 16
overbored is offline
post #36 of 37 Old 08-24-2013
Brewgyver's Avatar
Oops, duh! on me!
s/v My Sweet Girl!
Atomic 4
post #37 of 37 Old 08-26-2013 Thread Starter
THEFRENCHA's Avatar
So now I thanks ou all for your input I think I found what sent wrong and why I got engine overheating.
Not one major problem but couple of minor failures lead to overheating .
lt started with low water flow at exhaust. I thought that a first acid flush was enough and yes it did improve flow but a second flush has again improved the flow. I can see now that it is perfect simply has I connected pump to a bucket of fresh water and got a good sucking.
So it's not only what flow comes out of exhaust but also how much your engine is pumping
A 5 gals bucket is emptied in 2 minutes which seams to be the standard.
I changed the coolant. Level was fine but it was 4 years old and 250 hours on the engine.
Drained the coolant and flushed with fresh water a couple of times before refill.
I now believe that I am a bit over propped . Changed from a 2 blades to 3 blades ( not folding prop) last year and provided the old prop to manufacturer to set same pitching for the new one . I love the 3 blade as it did improve the ability of the boat maneuvering backward .
Which was my problem during winter as we dock the boat stern first.
So now with a bigger prop and I am probably asking more power from the engine .
Anyway I took the boat on a sea trial and all looks fine if I motor cruise under 3000 rpm which is absolutely fine by me At 2800 I reach hull speed so when we pushed it to 3200 last week ( strong tide) I probably pushed it too hard. I usually only use the engine in the winter to get out of marina docks. During the summer it's mostly sailing and this was the first time I had to motor for hours in a row .
So 2800 rpm it is, done with this engine, I feel I have already spent too much time on this problem. it's the end of summer , wind is picking up and lets go sailing !
Engines runs fine , no smoke at all, oil plug stays in place ...all is fine .
Yanmar 3GMF Overheating gordofloats Diesel 20 05-23-2012 12:13 PM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 02:40 PM
Yanmar 2 qm 15 overheating mystery NickAllinson Gear & Maintenance 9 06-26-2011 10:39 PM
Yanmar 3HN35F OVERHEATING kjango Gear & Maintenance 11 05-26-2009 10:29 PM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
