Minn Kota Endura C2 30 $99 - Page 2 - SailNet Community
 2Likes
post #11 of 28 Old 08-13-2013
Re: Minn Kota Endura C2 30 $99
FYI, you can get those U1 AGM 35AH batteries on Ebay for $65 shipped or so. At full throttle and if you are willing to run the battery all the way down (should really go 50%), you will get a bit over an hour with a 30lb thrust (roughly 1lb=1amp). I have verified this in the real world.
tschmidty is online now
post #12 of 28 Old 08-13-2013
no longer reading SailNet
Alex W's Avatar
Originally Posted by sstuller View Post
I've been using the C30 on my inflatable for several months to get to my mooring and it has done fine. Am using a 35 AH U1 AGM battery. It's light weight (23#?) and and there's no acid to spill. Will soon experiment with a 15 watt panel from Harbor Freight (with a cheap controller) to see if it will keep the battery charged. Since the dink is idle most of the time hopefully the panel will save me the trouble of recharging the battery on shore. Thanks.
A 15 amp panel puts about 1 amp at peak sun. Around here that would mean 5 days to top off a 35 amp battery that was drawn below 50% of it's capacity (maybe 45 minutes of full throttle or 2-1/2 hours of 8 amp draw).
A 50 watt panel seems more practical for cruising. On my boat I think I'd charge it off an echo charger, then it could also be charged from the sailboat's alternator. This is sounding like a pretty good alternative to my 2hp Honda (which I have to run pretty close to idle speeds anyway). What does a salt water rated electric outboard cost?
Alex W is offline
post #13 of 28 Old 08-13-2013 Thread Starter
JimMcGee's Avatar
The salt water motor is about $300.
At $99 the motor pretty much becomes a throw away, I've put more $$ than that into parts for the #$%@$% 3.5hp 2 stroke Tohatsu this season already.
The way I'm looking at is electric motors are improving by leaps and bounds. If I can get three seasons of light use out of the little sucker I'm ahead of the game and there will be something better/cheaper on the market when I'm ready to replace it.
I called Dick's today and they have one in stock. $15 more than Amazon but I can pick it up tonight and no shipping costs.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #14 of 28 Old 08-13-2013
I bought my Endura C30 on the WalMart website for $99.00. The real incentive was a shipping cost of 97 cents. Unbelieveable! Sometimes dreams do come true.
sstuller is offline
post #15 of 28 Old 08-14-2013 Thread Starter
JimMcGee's Avatar
Went over to Dicks and bought the Minn Kota last night. I'll stop over at Batteries + and pick up a gel battery for the dingy and give it a try this weekend.
JimMcGee is offline
post #16 of 28 Old 08-14-2013
There you go. Let us know how it works for you.
post #17 of 28 Old 08-16-2013
Since I can't seem to find the motor voltages at various speed settings for the Endura C30 I would like to post a logical(?) approach, At full speed - #5- it is 12 volts and draws 30 amps max.; At #4 it is 6 volts and 15 amps; #3 is 4 volts and 10 amps; #2 is 3 volts and 7.5 amps; and #1 is 2 volts and 5 amps. The voltage and current ratios are 1; 1/2; 1/3; 1/4; and 1/6. Am I being reasonable? Thanks.
sstuller is offline
post #18 of 28 Old 08-16-2013
Well, the voltage will stay the same but but your amp numbers are close-ish. But even at that the amps will vary depending on the load on the motor at a given setting. Are you just trying to figure out range?
post #19 of 28 Old 08-16-2013
I would like to know the amps at the various speeds so I can figure out how long the 35 AH battery will last. The Arizona Wind & Sun website gives the specs on the Universal 35AH battery i.e. how long it will last at various amp draws. The total voltage drop is always 12 volts. At the fastest speed all the drop is across the motor but as you increase the resistance with the speed coil the voltage left for the motor becomes less and less. Since the circuit is effectively a constant voltage device, as you increase the resistance with the speed coil the current must decrease i. e. E(12 volts) = IR. Thanks.
sstuller is offline
post #20 of 28 Old 08-16-2013
fryewe's Avatar
When I bought my trolling motor for my dinghy I looked at the FW and SW models and the difference in price led me to the FW model. Then I put one of these
on the shaft. Now I have a SW model. So far no corrosion!!
Also could have used
shadowraiths likes this.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
Minn kota? QuickMick Gear & Maintenance 15 06-12-2013 09:33 PM
Warm Spring Fosters Milfoil Growth In Minn. Lakes - CBS Local NewsReader News Feeds 0 06-12-2012 01:00 AM
Barnum, Minn., doctor pioneers cold-water rescues - Jamestown Sun NewsReader News Feeds 0 04-14-2012 05:30 PM
Anyone tried the Minn Kota or NOCO chargers?s? justonemoreproject Electrical Systems 0 03-19-2012 06:26 AM
Endura vs T-900 - need to decide Sunday jarcher Gear & Maintenance 5 06-29-2009 07:25 AM
