Minn Kota Endura C2 30 $99 - Page 3 - SailNet Community
 2Likes
post #21 of 28 Old 08-16-2013 Thread Starter
JimMcGee's Avatar
Re: Minn Kota Endura C2 30 $99
Originally Posted by sstuller View Post
I would like to know the amps at the various speeds so I can figure out how long the 35 AH battery will last. The Arizona Wind & Sun website gives the specs on the Universal 35AH battery i.e. how long it will last at various amp draws. The total voltage drop is always 12 volts. At the fastest speed all the drop is across the motor but as you increase the resistance with the speed coil the voltage left for the motor becomes less and less. Since the circuit is effectively a constant voltage device, as you increase the resistance with the speed coil the current must decrease i. e. E(12 volts) = IR. Thanks.
When you figure it out post those run times.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is online now
post #22 of 28 Old 08-16-2013 Thread Starter
JimMcGee's Avatar
Originally Posted by fryewe View Post
when i bought my trolling motor for my dinghy i looked at the fw and sw models and the difference in price led me to the fw model. Then i put one of these
Attachment 15278
on the shaft. Now i have a sw model. so far no corrosion!!
Also could have used
Attachment 15277
+1
post #23 of 28 Old 06-14-2014
TakeFive's Avatar
Any updates on battery performance with this motor? How about sources and specs for zincs to make it more saltwater resistant?
I bought the same 30 lb. motor in April 2013 for $80 after rebate. I used it a couple times last year (in fresh water), and considering taking it into the Chespeake in a couple weeks. Last year I used an extra Group 24 battery that I have in the basement. But that was way more capacity than I needed, and way too much weight to lug on/off the dinghy. So I've been looking at 22-35 Ah, I'd actually prefer to stay down around 22 Ah for the lighter weight.
Suggestions?
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #24 of 28 Old 06-15-2014
mitiempo's Avatar
I use a 76 AH Agm for my 55lb thrust Riptide and have run for 5 or 6 hours without a problem.
Zincs should not be necessary - just tip the motor out of the water when not in use. My Riptide has a zinc but next time I would try an Endura..
Brian
mitiempo is offline
post #25 of 28 Old 06-15-2014
Windseeker
Have people found that this motor dies when used in sw? If so buying one for this purpose would just contribute to our general trash problem and seems like a bad idea, however attractive it seems in the short term.
On the other hand if attaching a zinc or other approaches makes it work - awesome!
Any long term experiences out there?
theonecalledtom is offline
post #26 of 28 Old 06-15-2014
mitiempo's Avatar
The motors are sealed, whether the fresh or salt water versions. The zinc is only effective when the motor is in the water. If tipped up when not in use no problem.
Many I know use the fresh water (Enduro) is salt water without a problem.
Brian
mitiempo is offline
post #27 of 28 Old 06-16-2014
I'm using a c2 30 this year to push a 12 foot dinghy ( had a c2 40, they don't like being under saltwater, lasted two years before getting dropped, battery cable saved it from going to the bottom ) running it off Ryobi 4ah LiFePO4 batteries, runs for about 15-20 minutes so far, my mooring is about 1/4 mile from the dock. Now I just need to take a dead tool and cut the battery well off and glue it to the top of the motor.
Brewgyver likes this.
P35juniper is offline
post #28 of 28 Old 06-20-2014
TakeFive's Avatar
I've read a bunch of the linked info on battery drain of the C2 30, and went and looked at some 18, 22, 32, and 35 Ah SLA batteries. My brain hurts.
For my upcoming mini-cruise, I'm just going to use the Group 24 battery that I've had in the basement for a few years. I've got a perfectly matched pair of them hooked up in parallel to a sump pump. I'll take both of them to the boat, and move the current boat battery to the sump pump in my house.
I may need the extra battery capacity on the hook, so I'll keep both Group 24 batteries charging in parallel on the alternator while motoring. If/when I actually use the dinghy, I'll move it there. It's a pain lugging that big battery, but until I have a better idea how far I need to travel with the dinghy, I want the overkill of a 105 Ah. And if I don't use the dinghy, the extra capacity of having both batteries may come in handy.
After I have a better idea of my usage pattern of the trolling motor, I'll be better able to properly size a battery for it.
TakeFive is offline
Minn kota? QuickMick Gear & Maintenance 15 06-12-2013 09:33 PM
Warm Spring Fosters Milfoil Growth In Minn. Lakes - CBS Local NewsReader News Feeds 0 06-12-2012 01:00 AM
Barnum, Minn., doctor pioneers cold-water rescues - Jamestown Sun NewsReader News Feeds 0 04-14-2012 05:30 PM
Anyone tried the Minn Kota or NOCO chargers?s? justonemoreproject Electrical Systems 0 03-19-2012 06:26 AM
Endura vs T-900 - need to decide Sunday jarcher Gear & Maintenance 5 06-29-2009 07:25 AM
