3m 4000 or 42000? - SailNet Community
post #1 of 5 Old 08-13-2013 Thread Starter
3m 4000 or 4200?
Which one is the stronger bond. They both claim medium strength. I am not quite sure what the difference is between the two?
abrahamx is offline
post #2 of 5 Old 08-13-2013
overbored's Avatar
Re: 3m 4000 or 42000?
4000 is even messier to use. 4000 has better resistance to UV used as a bedding then 4200 works better for me
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 5 Old 08-13-2013 Thread Starter
I'm bedding some hand rails and winch island and figured i'd go with the stronger of the two. From what I can gather the 4200 is the stronger although the chart lists them both at 300psi tensile strength. With 5200 at 700psi. 4000 has a slightly lower stretch. I would say 4000 for general sealing, 4200 (seal/bond) if you want some added strength, and 5200 (BOND/seal) if you need much strength and are not planning on removing.
abrahamx is offline
post #4 of 5 Old 08-13-2013
overbored's Avatar
IMO the 4200 works the best to bed hardware. I don't like using 4000. 4000 is thinner. many here use butyl but I don't like it as the hardware keeps moving under load and the stuff keeps squeezing out and the bolts never stay tight.
post #5 of 5 Old 08-13-2013
Large Member
Butyl or butyl tape?
mdbee is offline
Autohelm 4000 Ladyhawke2 Gear & Maintenance 6 07-17-2009 10:50 AM
Autohelm 4000 Gulfislander Gear & Maintenance 1 03-02-2009 06:58 PM
Autohelm 4000 k7pqs Gear & Maintenance 8 12-06-2008 10:31 AM
Autohelm 4000 Gulfislander Gear & Maintenance 8 01-19-2008 11:48 AM
Autohelm 4000 Booher Gear & Maintenance 4 10-15-2003 05:09 PM
