Removing pawls and main gear on barient winch - Page 2 - SailNet Community
post #11 of 14 Old 08-13-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: Removing pawls and main gear on barient winch
Originally Posted by abrahamx View Post
These pics are better than my eyes. Maybe that is a set screw.
Yep, it's a set screw. The right-sized allen key will allow you to slide the collar off the shaft and it should all slide apart - out the top most likely.
Man, I wish my winches looked that good inside.
Classic30 is offline
post #12 of 14 Old 08-13-2013 Thread Starter
Do I just tap the pawls out from the underside?
abrahamx is offline
post #13 of 14 Old 08-13-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Just click the header.
winch - a set on Flickr
Pretty straight forward I would think. Just thought I'd ask.
Quick answer -
20130813_205713[1]
Different sources have different copy/paste functions. On Flickr you need to click on "more ways to share" get the embed code, copy that and then simply paste into your post.
Other image sites, e.g Photobucket, use a similar though slightly different method.
If you can get to an image source (URL must include .jpg or other compatible) you can simply copy the URL and paste into the image file box (thats the wee mountain postage stamp thingy) and away you go.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
The Following User Says Thank You to tdw For This Useful Post:
abrahamx (08-14-2013)
post #14 of 14 Old 08-14-2013
Classic30's Avatar
Dock
You should be able to simply pull them upwards with your fingers (watching out for the spring, which will attempt to orbit the moon the second it's released.. )
If they're in so tight you need anything stronger than pliers, something is wrong.
Worn holes for the Winch Pawls jvanommen Gear & Maintenance 20 12-02-2012 09:37 PM
Barient 22-39 Winch nickmerc Gear & Maintenance 15 10-03-2012 10:43 PM
Lewmar 25 Winch Pawls towen999 Gear & Maintenance 2 03-30-2012 03:05 AM
Mystery winch pawls SV Pohadka Gear & Maintenance 11 08-28-2011 08:49 PM
Barient Winch - How Bad Is It ? Jurgy Gear & Maintenance 5 05-10-2011 11:37 AM
