Shaft tube repair - SailNet Community
post #1 of 2 Old 08-13-2013 Thread Starter
Shaft tube repair
I just heard from my marina, apparently my shaft tube is leaking into the bilge and needs to be re-glassed. They want to pull the boat and let it dry for a few days before doing the fiberglass work. The boat is a 1978 C&C 36, will this fix require removing the prop shaft?
Sent from my DROID RAZR using Tapatalk 2
egent is offline
post #2 of 2 Old 08-13-2013
tommays's Avatar
Re: Shaft tube repair
Kind of depends ?
Mine had internal blisters that were fatal
new G10 tube
new hole
Set in Place
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
Hudsonian (08-14-2013)
B32 rudder shaft repair jb1528 Bristol 3 07-26-2012 09:41 PM
Catalina 27 Shaft Log Tube Repair Ajay73 Gear & Maintenance 4 05-26-2012 07:19 PM
Mismatch between stern tube OD and prop shaft/standard stuffing box size jameswilson29 Gear & Maintenance 20 12-27-2011 08:17 AM
Replacing the hose between the propeller shaft stuffing box and shaft log tube jameswilson29 Gear & Maintenance 34 12-14-2011 04:20 PM
Tricky Shaft Log Leak Repair JonG Gear & Maintenance 7 04-27-2009 09:00 PM
