Mounting ST winches - where to point the arms? - Page 3 - SailNet Community
post #21 of 22 Old 08-15-2013
Re: Mounting ST winches - where to point the arms?
Reminds me of the semi-custom 45-footer that a friend had built at a yard with a fairly doof reputation. Four self-tailing winches in the cockpit, all installed with the tailing arms installed in the exact smae orientation, relative to the boat. Which made the portside ones just fine, and the starboard sides ones totally useless.
From which one might learn that "the right way" is a mirror image, not an identical position, on the opposite sides of the boat.
hellosailor is offline
post #22 of 22 Old 08-17-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
Well, I removed the old winches, filled the holes, drilled new holes and fitted the new winches today. The port side arm points at about 120degrees, the starboard about 300 degrees. Basically how the instructions said. Seems OK like that.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
VP MD2040B rocker arms oil lube advice needed scud Diesel 9 08-29-2012 03:51 PM
Point vs. Counter Point: Kony 2012 - The Trinitonian NewsReader News Feeds 0 06-09-2012 12:20 AM
Sailing / World Championships / Brothers up in arms NewsReader News Feeds 0 03-22-2012 12:30 AM
Mounting blocks for mast mounted winches! ntheyer Gear & Maintenance 7 12-12-2006 02:19 PM
