-   -   Flexifold and strut (http://www.sailnet.com/forums/gear-maintenance/102558-flexifold-strut.html)
davidpm 08-15-2013 12:19 AM
Flexifold and strut
1 Attachment(s)
First off how does one remove this propeller?
Second, sorry about not having a picture that shows more but after I took the picture I got to thinking that this home made strut may not be as strong as it should be.
They guy put on a much longer shaft so he could fit a larger prop.
You can pretty much make out the size of the new strut.
The unsupported section is maybe two feet.
I suspect it is strong enough to drive the boat I'm just thinking that even a minor event like a prop wrap will bend it causing immediate failure.
Fstbttms 08-15-2013 12:27 AM
Re: Flexifold and strut
1.- Remove the zinc.
2.- Remove the cover plate.
3.- Remove the set-screws that secure each blade pivot pin.
4.- Drive out the pivot pins.
5.- Remove the blades.
6.- Remove prop nut set screw
7.- Back the prop nut off but do not remove.
8.- Put a deep socket on the nut, then attach prop puller.
9.- Remove prop.
rugosa 08-15-2013 08:09 AM
