Need high-current 12VDC deck plug - SailNet Community
 1Likes
post #1 of 18 Old 08-15-2013 Thread Starter
I'm looking for a watertight deck plug to be used in the power line of my wind generator. I haven't been able to find anything in my web searches that looks suitable. Here are the requirements:
* water tight
* needs to be able to handle 4AWG wire
* needs to handle at least 20 amps current
* preferably installable without special purpose crimpers
The reason I want a plug instead of a continuous run from the wind generator to the voltage regulator is that I live in a hurricane zone and I want to be able to just unbolt the whole wind generator and tower and toss it in the back of the truck for hurricane prep. I sometimes have to do this several times a year. I don't want to have to deal with pulling wires every time a hurricane threatens.
Any ideas?
Thanks in advance!
jim2ksb is offline
post #2 of 18 Old 08-15-2013
denverd0n's Avatar
Re: Need high-current 12VDC deck plug
Nothing specific to recommend, but I would look at connectors for trolling motors.
denverd0n is offline
post #3 of 18 Old 08-15-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Aviation stuff is top notch. The implications of a failure are higher
AC 250V 25A 4 Pins Aviation Electric Deck Connector PLS20 4 | eBay
Melrna likes this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #4 of 18 Old 08-15-2013
Tim R.'s Avatar
I put a plug on mine that is just below the generator inside the pole. It is from a UPS. I placed it within the pigtail from the generator. I can bring the pole to horizontal and then remove the wind gen. The pole stays wire tied to the life lines thus reducing windage.
Aliexpress.com : Buy 10PCS/lot 175A 600V SMH twin pole large current plug connector connector UPS plug storage battery charging plug low shipping from Reliable 175A 600V suppliers on HOBBY KING TECHNOLOGY LTD
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #5 of 18 Old 08-15-2013
A watertight connector capable of accepting 4AWG wire is going to be large and expensive. Look for watertight connectors in 75~100Amp range and see what I'm talking about. Those would be able to handle your wire size. 20A connectors are sized for much smaller wire (typically 12~10 ga.)
Not all who wander are lost. - JRR Tolkien
Kajungizmo is offline
post #6 of 18 Old 08-15-2013
remetau's Avatar
Your wind gen has a built in rectifier to put out 12v DC?
Don & Diana
sv Re Metau an HC33t
remetau is offline
The Following User Says Thank You to remetau For This Useful Post:
MarkSailor (08-16-2013)
post #7 of 18 Old 08-15-2013
Yeah, 4WAG would be way overkill, 10-12 would be fine. I'd second the trolling motor connectors which are obviously able to handle 30-50 amps without an issue.
tschmidty is offline
post #8 of 18 Old 08-15-2013
Puget Sound Pounder
kellysails's Avatar
Trolling motor connectors or electric down rigger connectors. Both would work.
With 10AWG you can go 15 feet with only a 5% voltage drop on a 20amp draw.
With 8AWG you can go 25 feet with only 5.2% voltage drop with a 20 amp draw.
Send me a PM and I will forward along my automated excel wireloss worksheet. I use it all the time. Very handy.
kellysails is offline
post #9 of 18 Old 08-15-2013 Thread Starter
I found one from Marinco called ConnectPro that handles 6AWG, and is supposed to handle 25A. I think that one will do. Thanks to all for the suggestions!
jim2ksb is offline
post #10 of 18 Old 08-15-2013
Maine Sail's Avatar
I'd suggest bringing the wires into the boat via two Scanstrut watertight deck glands, a pos & neg one, and terminate them at two BlueSea power posts or a dual pos/neg bus bar inside the boat.
This way you can use standard marine lugs. When you need to remove the wind gen just disconnect inside the boat and pull the wires through the deck glands. Two dowels the OD of your wire will seal the glands when the wires are pulled..
______
-Maine Sail / CS-36T
Maine Sail is offline
Proper way to tap into 12VDC wire? CarbonSink62 Electrical Systems 48 05-10-2013 01:21 PM
Any Videos of Moderate to High Crosswind/Current Docking? NCC320 Seamanship & Navigation 7 06-16-2011 02:34 PM
windlass 12vdc pc37howard Pacific Seacraft 3 05-05-2011 07:29 AM
through-deck mast plug installation LookingForCruiser Gear & Maintenance 5 07-08-2009 06:37 PM
Prada goes from high fashion to high seas - El Paso Times NewsReader News Feeds 0 05-09-2007 02:15 AM
