Volvo Penta Saildrive Prop stuck open - SailNet Community
post #1 of 3 Old 08-16-2013 Thread Starter
Windseeker
I'm new to the whole folding prop thing.
Recently we replaced ours with a new unit. When bringing the boat home we were running a bit behind and I wanted to clear out the cobwebs so I push to 2800rpm. After about a minute the boat suddenly started vibrating. not terrible but enough to notice and back down.
In neutral all is smooth. In gear the boat vibrates in reverse and forwards (both gears work) with the vibration starting at low RPM and increasing steadily as RPM increases.
Looking under the boat the propeller seems okay, but stuck open.
Any ideas what might have happened?
Lesson: I had a shakedown sail, I should have pushed the engine harder then.
theonecalledtom is offline
post #2 of 3 Old 08-16-2013 Thread Starter
Windseeker
Re: Volvo Penta Saildrive Prop stuck open
Best guess fishing wire? Props nice simple mechanical devices and otherwise unlikely to go wrong until worn out / bashed with something?
post #3 of 3 Old 10-15-2013 Thread Starter
Windseeker
In the end this turned out to be grease that had coagulated hard in the prop teeth. Since this was cleaned up the prop has been working great again.
Spun prop Volvo saildrive SoC Gear & Maintenance 5 12-11-2014 08:42 AM
Thread data of the 2 anode screws of Volvo penta saildrive 12o Ulfilas Diesel 1 01-17-2013 11:36 AM
prop for a 18hp volvo penta dubon Diesel 0 08-04-2012 02:09 AM
Volvo Penta 50S saildrive parts cousineddy Gear & Maintenance 1 11-28-2011 11:20 AM
bavaria 44 Volvo Penta MD55 w/ms25sa saildrive indecission Bavaria 1 02-19-2010 12:04 PM
