Best "Rigging Parts Configuration" 18' - SailNet Community
post #1 of 5 Old 08-16-2013 Thread Starter
Hi,
I have been working on this rig since Feb 2012.. (it's a '74 Laguna Windrose)finally getting around to replacing some rigging parts. Every T jaw is bent so I'll be replacing those (boy those bend easily). My question is what's the best 'parts connection configuration' is best? This should be an easy one for most of you but it's like rocket science for me! I couldn't find much on it...
I had someone tell me "if it fits, it goes" in relation to rigging parts.. is this ok to follow or not? I have seen alot of different setups.
I included pic of the forestay, backstay & shrouds.. boat is in the driveway but the parts are visible.
I would like to have the most accurate reliable connection for the forestay (and a "quick release pin" would be great. Currently the forestay has a quick release to loosen the cable but I would like to use a quick release of some sort at the final connection instead of the pin every time. It also has an extender, turnbuckle and some shackles.
The backstay works ok and is pretty simple.
The shrouds are (in my opinion) a conglomeration of shackles etc but seem to do the job, but the toggles are all bent.
Any recommendations on the best configuration to use?
Thanks!
Shawn T
Wichita KS
Amateur_Expert is offline
post #2 of 5 Old 08-20-2013 Thread Starter
Re: Best "Rigging Parts Configuration" 18'
On both the port and starboard outer shrouds I have 2 toggles.. they kinda bind up and bend sometimes.. would a small extender be worth a try to lessen the amount of toggles or does it not really matter?
I plan to replace that forestay extender.. is it ok to have the extender as your main connection at the stemhead?
post #3 of 5 Old 08-20-2013
I don't discuss my member
zz4gta's Avatar
In my opinion, you need new standing rigging. All of it. You can continue to use what you have, it'll probably never fail, but there are a tremendous amount of potential failure points.
There should be a T-ball fitting at the mast, a swage and turn buckle at the bottom with a toggle, cotter pin and clevis pin. That's it. When I bought my boat I had some "extra" parts, some were bent, old. I replaced them all and have been very happy ever since. I know they won't fail.
I do not recommend quick release pins for standing rigging. Some work better than others, but you still need to use a safety with them.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #4 of 5 Old 08-20-2013 Thread Starter
Thanks for the input zz.
That's kind of the "boat" I am in with the "extra parts". I pretty much left it except for replacing a toggle and adding one and replacing a t-jaw. I was thinking about ordering some more replacements. I would like to replace the rigging this winter maybe.
It sounds like less is better... I will have to look up the parts you mentioned.
post #5 of 5 Old 08-21-2013
zz4gta's Avatar
One thing to keep in mind, especially on a rig that will be stepped and unstepped, is that you need to make sure you have toggles in place to align the load with the shroud. The entire assembly should be in a straight line and free to "swivel" in all directions so when you tighten a shroud, the hardware lines up.
Looks like this boat has had it's rig stepped and something was binding. It happens to me almost everytime I step my mast, just need to stop, straighten out the hardware, and continue.
zz4gta is offline
Tags
rigging configuration
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
experience with "rigging only" online store peterchech General Discussion (sailing related) 21 04-12-2012 11:13 PM
Moving chainplates outboard (from "through deck" configuration), I have a question.. chrisncate Gear & Maintenance 56 10-28-2011 03:05 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
