Battery-powered Trolling motor - SailNet Community
 2Likes
  • 1 Post By dabnis
  • 1 Post By bobmcgov
post #1 of 7 Old 08-17-2013 Thread Starter
Exclamation Battery-powered Trolling motor
Hey y'all!
I'm sealing the deal on a 13-ft. CFJ next Tuesday (first boat! ). I'll be sailing on the James River, which is tidally influenced and has a very weak current, but strong enough to make it a miserable chore to paddle back to the marina. I'm look to buy a very, very small battery-powered trolling motor, maybe 1 hp, definitely 100% waterproof (also planning on capsizing a good deal), inexpensive, and lightweight. I've looked around online but can't really seem to find anything that fits my budget or my criteria... any ideas?
I sail.
bradleyswissman is offline
post #2 of 7 Old 08-17-2013
The most female moderator
Donna_F's Avatar
Dock
Re: Battery-powered Trolling motor
How could the motor be 100% waterproof?
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
The Following User Says Thank You to Donna_F For This Useful Post:
bradleyswissman (08-18-2013)
post #3 of 7 Old 08-17-2013 Thread Starter
Maybe not 100% waterproof, but it needs to not be messed up if it becomes submerged.
I sail.
post #4 of 7 Old 08-17-2013
All the trolling motors I have seen have the motor underwater with the "controls" up top. I don't think the controls would be happy under water, especially if there is any salt in it.
Maybe a good set of oars?
Paul T
bradleyswissman likes this.
dabnis is offline
The Following User Says Thank You to dabnis For This Useful Post:
post #5 of 7 Old 08-18-2013
baDumbumbum
bobmcgov's Avatar
Most of your saltwater digital trollers have potted electronics in the head, so theoretically waterproof. Probably a few switches wouldn't like being submerged, tho they would dry out eventually. You'd also need an AGM or gel battery if it's going to be upside down, and it would need to be secured well. *shrug* It is doable, tho the effect on a small dinghy of a 16lb troller plus 40lb battery is not trivial. My general feeling is don't put any sort of motor on a boat you plan to roll.
There's the Electric Paddle, which seems ideal until you see the price tag.
FWIW, a 45# thrust trolling motor -- a medium sized unit -- equals about a 3/4hp gas engine in real world terms. That's what we have on our SJ21. A 30# troller would move your dinghy just fine, but I'd advise a used one if you expect to dunk it.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
The Following User Says Thank You to bobmcgov For This Useful Post:
post #6 of 7 Old 08-18-2013 Thread Starter
Thanks, all! I'll probably end up using one of our numerous canoe paddles, and just stow it somewhere out of the way. It wouldn't cost anything, anyways....
I sail.
post #7 of 7 Old 08-18-2013
manatee's Avatar
Scull and yuloh articles for small boats:
How to Scull , Yuloh a Boat
yuloh small boat - Google Search
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
Tags
dinghy sailing , motor , trolling motor
trolling motor mcnabbstacy Gear & Maintenance 3 07-29-2012 11:14 AM
Trolling Motor to Battery Bank? snider General Discussion (sailing related) 10 06-17-2012 08:47 PM
Solar charger size - trolling motor battery drcoop Electrical Systems 2 05-13-2012 03:56 PM
Testing my trolling motor Hookturn Gear & Maintenance 6 03-09-2012 03:39 PM
trolling motor generator dodgeboatguy Gear & Maintenance 0 07-18-2007 10:24 PM
