Yanmar water backflow - SailNet Community
post #1 of 6 Old 08-19-2013 Thread Starter
Sea Alles's Avatar
This has happened twice within the week. Upon shut down of our 3 cylinder Yanmar, it syphons water back into the manifold, preventing the start of the engine. The first time was a four hour search. Today the diagnosis was much quicker. Both times the boat had six adults aboard and the wet exhaust outlet would have been under water. I don't want to tell all our guests to move to the bow so I can shut down!! I am getting good at sailing in the harbour.
The exhaust line appears to have an upward loop--like a sink drain, but that doesn't stop the backflow. Can a check valve/anti syphon be installed? I recall seeing a flap on the hull of an exhaust outlet-I assume to prevent this issue.
Any help appreciated
Thanks
Kevin Alles
Bayfield 32 Sea Alles
Sea Alles is offline
post #2 of 6 Old 08-19-2013
Remember you're a womble
PaulinVictoria's Avatar
Re: Yanmar water backflow
How high is the loop? Might be that it's high enough normally, but not when the extra load is onboard.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #3 of 6 Old 08-19-2013
Check your anti-syphone valve in the loop. There should be one installed
aa3jy is offline
post #4 of 6 Old 08-19-2013 Thread Starter
Sea Alles's Avatar
Thanks for the info. I'll investigate these suggestions.
Kevin
post #5 of 6 Old 08-19-2013
On most every boat I've been to the exhaust outflow is above the waterline. IMO if it isn't when you've got 6 people onboard you should re-locate it higher up.
Maxion is offline
post #6 of 6 Old 08-19-2013
JimsCAL's Avatar
Do you have the "low rise" or "high rise" mixing elbow? If the former, a change to the later would help. The high rise is a casting that makes a 180 degree turn, with the exhaust entering up and the exiting down.
JimsCAL is offline
Yanmar 3gm raw water pump 34crealock Pacific Seacraft 8 04-09-2013 03:59 PM
winterizing yanmar 2gm raw water nodders Diesel 4 11-05-2012 05:55 PM
Yanmar 2GM raw-water pump? HELP ltgoshen Gear & Maintenance 3 09-24-2012 02:03 PM
C&C 32 raw water pump for 2gm yanmar bigchump C & C 6 04-15-2011 09:55 AM
Yanmar Water Pump dashman Diesel 1 08-16-2009 03:02 PM
