Aries windvane maintenance - SailNet Community
post #1 of 5 Old 08-19-2013 Thread Starter
JordanH's Avatar
Hi All,
My Contessa 26 came with an installed Aries windvane; I have not used it in the past 2 years but got around to installing the rudder and vane/paddle yesterday. All the bits and parts move... but with some resistance. Mainly looks to be spiderwebs and such.
I plan to test it out this week but I'm wondering what maintenance I should do before I head out. Should I lube the joints? What do you suppose would work best? Will a simple spray down with WD-40 do the trick or should I use better grease?
What other maintenance items should I check/replace before giving it a go? I'll be replacing the rudder-lift release line and the rudder safety line and may or may not replace the others.
Now if I can find the chain for my tiller I'll be good to go...
JordanH is offline
post #2 of 5 Old 08-19-2013
Skipper Jer's Avatar
Re: Aries windvane maintenance
Might try this site for hints and spare parts if needed.
Aries - Providing Vane Gear Spares and information
If the vane doesn't work out for you PM me, I'm in the market.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #3 of 5 Old 08-19-2013 Thread Starter
JordanH's Avatar
Thanks. I've checked out the site but it doesn't mention proper care / lube instructions. I suppose I'll e-mail them.
I have no intention of selling the vane, however, I'll keep you in mind should I decide to let it go.
JordanH is offline
post #4 of 5 Old 08-19-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
As far as I'm aware, a bit of light machine oil on moving parts is about it.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #5 of 5 Old 08-20-2013
Don't use auto grease or WD-40. Both attract and retain salt.
Over here is marketed a spray product called 'INNOX'. I think it originated in Canada, so should be available in the USA. The trawler fishermen here use it for any light lube work around their boats and put me on to it. I have used it for many years with good results, even on my sheet winches.
The same company also flogs a product called 'Lanox' which is more greasy (being lanoline-based) and good on steering cables etc if they are below decks.
If you must use grease, I would suggest proper marine grade winch grease or outboard motor steering bearing grease.
arvicola-amphibius is offline
wheel drum for aries windvane bluwateronly Gear & Maintenance 17 04-13-2014 07:45 PM
Is this an aries windvane n0w0rries General Discussion (sailing related) 5 05-16-2013 01:17 PM
Aries Windvane - $800 (Georgetown, SC) ltgoshen Gear & Maintenance 2 02-01-2013 07:33 PM
Aries windvane loup30s Gear & Maintenance 0 01-27-2012 08:12 AM
Aries windvane servo rudder repair running SailNet FAQ 3 12-29-2009 05:24 AM
