I'm having trouble finding hardware - Page 3 - SailNet Community
 2Likes
post #21 of 29 Old 08-21-2013
Re: I'm having trouble finding hardware
you could try fastenal as well.
http://www.fastenal.com/web/products/fasteners/bolts/cap-screws-hex-bolts/_/Navigation?term=&termca=&termpx=&sortby=webrank&sortdir=descending&searchmode=productSearch&zipcode=&filterByStore=&filterByVendingMachine=&r=~|categoryl1:%22600000%20Fasteners%22|~%20~|cate goryl2:%22600001%20Bolts%22|~%20~|categoryl3:%2260 0003%20Cap%20Screws%209and%20Hex%20Bolts%22|~%20~| attrdiameter:390|~%20~|attrlength:2010|~%20~|sattr 03:^%22Stainless%20Steel%22$|~
You have a choice of 316 or 18-8
You can order only one if you want. The price however will knock you over.
jbogart is offline
post #22 of 29 Old 08-21-2013
Flat or Oval head machine screws or strut bolts are pretty common up to 6". I've never seen them longer than that. If you can cut the blocks down to where you can use a 6" machine screw your project will get a whole lot easier and cheaper.
hopcar is offline
post #23 of 29 Old 08-21-2013 Thread Starter
There is a link to photos a few posts up. I'm using 4200 for bedding and varnish for protection
abrahamx is offline
post #24 of 29 Old 08-21-2013
If you are are still stuck on this project how about coupling nuts :basically long nuts screw in from both ends. Drill up from underside and use large fender washers and hex machine bolts to make up the needed extension. Measure careful and cut to allow a bit of gap where up meets down.
abrahamx likes this.
Capt Len is offline
post #25 of 29 Old 08-21-2013 Thread Starter
not stuck. As stated earlier I am just going to chop off an inch of the block and use 6 inch bolts from mcmasters ... $50 worth of them
abrahamx is offline
post #26 of 29 Old 08-22-2013 Thread Starter
Order placed. $60 for 12 bolts. Thanks for the heads up on some places. I had a local place (tradesman) look for me and he called back and said all he could find was 6" but he did find one place that had 3/8 x 8" fully threaded for $19 . I ended up going to mcmaster they had the 3/8x6 for $5. Fastenall had them for $9. 4 buck mark up per bolt unless they were fully threaded but still.
abrahamx is offline
post #27 of 29 Old 08-22-2013
xmarina owner
Send a message via Yahoo to cptskip
Jamestown dist---has then ship same day
cptskip is offline
post #28 of 29 Old 08-22-2013 Thread Starter
they were a few bucks a bolt more though.
abrahamx is offline
post #29 of 29 Old 08-23-2013 Thread Starter
ordered from mcmaster yesterday morning and its in the ups truck en route as we speak. just thought I'd update on the speedy delivery. Should be here around 3ish when the ups truck usually comes by. Plus they were the cheapest and no relation to the company, just a happy customer.
abrahamx is offline
winch trouble QuickMick Gear & Maintenance 4 07-06-2010 03:05 PM
a bit of trouble with the wind freddyray General Discussion (sailing related) 7 05-12-2009 12:56 AM
I'm having trouble finding info on Boatex or the avg cost Lancer28 Boat Review and Purchase Forum 4 10-22-2007 02:38 PM
MD-11C RPM,s Trouble flydude3 Gear & Maintenance 0 05-22-2004 05:51 AM
