I'm having trouble finding hardware - SailNet Community
 2Likes
post #1 of 29 Old 08-19-2013 Thread Starter
I leveled the winch on my Tartan 30 with a wood block. I now need 7 inch 5/16 Stainless bolts with a champfered/countersink head to fit my winch. Problem is, every local place I call wants me to order 25-50 and I only need 12. Plus they are about 4 bucks a pop. I am having a hard time finding an online site to order from. anyone have any advice?
abrahamx is offline
post #2 of 29 Old 08-19-2013
Learning the HARD way...
eherlihy's Avatar
Re: I'm having trouble finding hardware
McMaster-Carr
McMaster-Carr
eherlihy is offline
post #3 of 29 Old 08-19-2013
eherlihy's Avatar
Fully threaded they are $7.85 each, and partially threaded they are $5.81 each.
McMaster-Carr
eherlihy is offline
post #4 of 29 Old 08-19-2013
overbored's Avatar
how high did you make the block? it will be very hard to find flathead bolts that long. bolts that long will not be as strong in shear load, they may a tendency to bend under load. the higher the block the smaller the load the winch mounting can handle. I never saw a problem with the winch mounting on a Tartan 30
"GOLD RUSH" PRINDLE 16
overbored is offline
post #5 of 29 Old 08-19-2013 Thread Starter
[QUOTE=eherlihy;1076288]Fully threaded they are $7.85 each, and partially threaded they are $5.81 each.
McMaster-Carr[/QUOTE
7" ones? Sorry, I am just not seeing them. I really need these but am not seeing much more than 5 inches or so.
abrahamx is offline
post #6 of 29 Old 08-19-2013
fryewe's Avatar
Jamestown Distributors has 5/16 18 thread fasteners on a piece by piece basis in both bronze and SS (304) at 8 inches length. Precious at 12-13 bucks per machine screw.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #7 of 29 Old 08-19-2013
eherlihy's Avatar
[quote=abrahamx;1076370]
Follow the link. Select Inch, then select Stainless, then select the length (they go up to 20") then select the thread that you want...
eherlihy is offline
post #8 of 29 Old 08-20-2013
Remember you're a womble
PaulinVictoria's Avatar
How did you mount the block?
Why not drill up inside the block a few inches from the bottom, make the hole the same size as the washers (well, very slightly bigger) and just use a shorter bolt to mount the winch? Will be stronger, easier to find and cheaper. I would think 3 inches of wood isn't going to be significantly weaker than 7 inches of wood.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #9 of 29 Old 08-20-2013 Thread Starter
Well the block is glued on so I need the strength of the bolts. If the winch will allow, possibly I could drill the hole bigger if need be, I will probably go with 3/8 bolt for some added strength.
abrahamx is offline
post #10 of 29 Old 08-20-2013 Thread Starter
Now after thinking about it I am not sure why he built those so high. It looks like I could take off a couple inches and it would be stronger and cheaper on hardware.
abrahamx is offline
winch trouble QuickMick Gear & Maintenance 4 07-06-2010 02:05 PM
a bit of trouble with the wind freddyray General Discussion (sailing related) 7 05-11-2009 11:56 PM
I'm having trouble finding info on Boatex or the avg cost Lancer28 Boat Review and Purchase Forum 4 10-22-2007 01:38 PM
MD-11C RPM,s Trouble flydude3 Gear & Maintenance 0 05-22-2004 04:51 AM
