Chain Plates and Mast Tang Question - SailNet Community
post #1 of 5 Old 08-20-2013 Thread Starter
casey1999's Avatar
Why are chain plates built and installed with a much stronger design than the tang they attach to on the mast? Most sail boats have a very long and large cross section chain plate held with many bolts, then it attaches to a relatively small tang held by one bolt on the mast. We seem to concentrate most on the condition of the chain plate but what about the mast tangs and bolt?
casey1999 is offline
post #2 of 5 Old 08-20-2013
overbored's Avatar
Re: Chain Plates and Mast Tang Question
the many bolts are because of the material that they are attached to. the fiberglass or wood hull/ bulkhead are no where near as strong as the aluminum mast material
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 5 Old 08-20-2013 Thread Starter
casey1999's Avatar
Good point...
post #4 of 5 Old 08-20-2013 Thread Starter
casey1999's Avatar
But the interesting thing it always seems the chain plate fails by cracking right at the deck penetration. I realize that with stainless this is probably due to stress corrosion cracking. So if I use say silicon bronze, would this not be a better material? And I would think the small mast tang would see a lot of fatigue failures as the mast (even in a well tuned rig) has a lot of movement due to normall stresses it sees.
post #5 of 5 Old 08-20-2013
aeventyr60's Avatar
I replaced all the tangs before going offshore. Earlier this year when I had the mast out I found a tang at the mast head with a small crack, replaced this one as well. So, yes the tangs do fail....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
Chain Plates eherlihy O'Day 15 01-24-2017 10:59 AM
Chain plates Ruthlessrider Grampian 12 08-16-2013 01:11 AM
chain plates Bob142 General Discussion (sailing related) 8 06-14-2012 01:33 AM
chain plates amblin909 Announcements and Suggestions Box 2 12-10-2009 06:09 PM
Chain plates are out, now what? jrd22 Gear & Maintenance 11 12-30-2007 11:06 AM
