Installing the Signet sensor paddlewheel under water - SailNet Community
post #1 of 2 Old 08-20-2013 Thread Starter
Kynntana (Freedom 38)
gamayun's Avatar
Has anyone replaced the paddlewheel for their speed sensor while the boat is in the water? I have an old Signet and have bought the replacement part, which has a pin similar to those on watch bands. I was thinking of diving the boat and trying to install it that way rather than pull the transducer out from the inside. Is this possible to do? Is there any trick to keeping the pin in place while pushing the paddlewheel into the slot?
gamayun is offline
post #2 of 2 Old 08-20-2013
Gary M's Avatar
Re: Installing the Signet sensor paddlewheel under water
If I remember my old signet correctly it is like most through hull speedo's. You unscrew the transducer at the through hull fitting and pull it out. Then just put your hand over the opening, pick up the new through hull and insert it.
There are two o-rings on the insert to keep it from leaking. Probably let in a couple of cups of water. Do not think you can even do it from under water.
Good Luck
Gary M is offline
Installing thru hulls in the water?? NewportNewbie General Discussion (sailing related) 21 10-16-2013 01:03 AM
Installing inline fresh water Filter shipley Gear & Maintenance 2 04-24-2010 10:00 PM
Can you change out a through hull speed sensor while in the water? donhaller Gear & Maintenance 9 07-17-2009 10:23 AM
Installing A Drinking Water Filter - 36T Maine Sail CS Yachts 3 02-16-2008 11:37 PM
Installing Vents for water Tanks mogul11 Gear & Maintenance 0 05-12-2003 11:00 AM
