Going up the mast - Page 2 - SailNet Community
 1Likes
post #11 of 28 Old 08-22-2013
Kynntana (Freedom 38)
gamayun's Avatar
Re: Going up the mast
I use to climb (just at the beginner level) and was taught to tie in with a double figure 8 on a bight. Then an overhand knot can tie off the working end over the standing end to add redundancy. I know the bowline is a secure knot and holds some heavy loads, but I'm curious if it is trusted to not slip loose?
gamayun is offline
post #12 of 28 Old 08-22-2013
I just went up the mast on our 28' sailboat for the first time a couple of weeks ago...had a bosun's chair and was winched up (two halyards). From what I understand, it is tough work winching up. Fortunately our neighbor was in his slip, as my wife certainly would not have been able to do it. It is a bit nerve racking as well as the higher you go the boat certainly rocks a bit with all the weight up there - but settles down...and as calm as the day may be, once you get up there it will certainly start to pick up!
If winching, I would suggest hauling yourself up on one halyard while the slack is taken up with the wincher below...
Good Luck...
nolesailor is offline
post #13 of 28 Old 08-22-2013
Senior Smart Aleck
jameswilson29's Avatar
Bring a camera and a video recorder: My YouTube video:
jameswilson29 is offline
post #14 of 28 Old 08-22-2013
TECHNIQUES FOR MAKING A TRIP UP THE STICK SAFER
Good Old Boat - Up the mast article
kentobin is offline
post #15 of 28 Old 08-22-2013
Tim R.'s Avatar
All good info so far. I will add that you should not rely on a self tailing winch when hoisting someone up a mast. See the warning below.
When there are only two of us we use two halyards both running through locked clutches. One to the hoisting winch and the other nearby to take up slack every 5 or so ft. Our halyards are led to the cockpit. We use climbing harness for short trips and bosuns chairs and harness for longer trips. We also use one of our jack line tethers wrapped around the mast a few times with both ends hooked to the harness. If both halyards fail the tether tightens and stops the fall. It also keeps you near the mast should it be rolly. The person going up will try to climb to help the winching person.
Lewmar issues safety warning on self-tailing winches - Ocean Navigator - March/April 2011
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #16 of 28 Old 08-22-2013
Location: surrounded by three small children and 2 dachshunds + foster doxies
We've been up the mast 5 times in the last two weeks. It was easiest with a third person to tail.
E
windwalker is offline
post #17 of 28 Old 08-22-2013
dan8152's Avatar
great thread and just in time! I just got a new to me Catalina 30 that has mast steps and I will need to go up the mast for winterization soon. I free solo'ed climbing my mast on my C22 when I had to redo a hallyard but my Tall rig is a bit higher and scarier.
dan8152 is offline
post #18 of 28 Old 08-22-2013
Crealock 37
sailak's Avatar
Dock
A way to ease the amount of work is to use block and tackle to hoist you up the mast. I have a 4 to 1 tackle, I use a halyard to raise one set of blocks to the masthead ,the bottom set of blocks is attached to the person ascending. With a light person you can almost pull yourself up the mast using this system. I put the running end through a block at the mast-base and lead it aft to a large winch (or you could use your anchor windlass if equipped with a rope drum).
For safety I have a line attached to my harness that is tied to the running end of the block/tackle with a prusik knot. If my helper forgets to tail, etc the prusik will arrest my decent.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #19 of 28 Old 08-23-2013
glymroff's Avatar
Location: Winter/Spring - Sailing, Summer/Fall - Vermont
ATN worked for me quite well. Also used alternate safety line to harness.
Concur w/ no one under you. I have the admiral on a winch taking up slack on the safety line. Only one burning energy is me. Flag or spinaker line for tool bag/hoist for the things that are ALWAYS forgotten :-)
Got it used at Bacons, looked like it was tried maybe once! It does take some practice but once you 'get it', it works great.
I hated the bosun's chair.
glymroff is offline
post #20 of 28 Old 08-23-2013
S/V Glenn E
Lubrdink's Avatar
Our dockmate Michael up the mast.
"Sailing with a hero"
Honoring S/Sgt Glenn English, Jr, Congressional Medal of Honor for heroism that cost his life in Viet Nam, 9/7/70.
Newport 27 built 1970-Hull # N270088
Lubrdink is offline
Tags
climbing the mast
Video from the top of the mast: repairing mast light wires jameswilson29 Gear & Maintenance 7 06-03-2013 03:45 PM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
