Why not cheap refrig components? - SailNet Community
 3Likes
post #1 of 28 Old 08-22-2013 Thread Starter
glymroff's Avatar
Location: Winter/Spring - Sailing, Summer/Fall - Vermont
If insulation is really the key to a good ice box to refrig mod, and given that the cost of most marine kits are from 600 - 1000 or more. Why not rig up a way to use a small cheap frig as the source of components and replace the parts every year or two or three.
Meaning, how many $80 refrigerators does it take to equal a $1000.00 kit?
Am I missing something?
Thoughts?
I'm about to go down this path, and maybe post the pics as well...
glymroff is offline
post #2 of 28 Old 08-22-2013
bljones's Avatar
re: Why not cheap refrig components?
what the refrig?....
It's 5 o'clock somewhere:
bljones is offline
post #3 of 28 Old 08-22-2013
Skipper Jer's Avatar
Re: Why not cheap refrig components?
The $80 refrigerators operate on 110 volts AC. The $600 to $1000 conversion kits operate on 12 to 24 volts DC and pull maybe 3 to 5 amps. The small AC refrigerators pull about 1.25 amps at 110 vac for 137 watts (about depending on power factor) AND then power consumption of the inverter needed to convert 12 VDC to 110 VAC. You are paying for efficiency.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #4 of 28 Old 08-22-2013 Thread Starter
glymroff's Avatar
turning the ice-box into a refrigerator.
sorry for the cryptic.
glymroff is offline
post #5 of 28 Old 08-22-2013 Thread Starter
glymroff's Avatar
Is that 137 watts per hour, on the AC components?
glymroff is offline
post #6 of 28 Old 08-22-2013
Plus the power it takes to run the inverter. I don't know how long the cheap
refrigerators run, it depends on the insulation, temperature settings outside and inside in the frig.
"Is that 137 watts per hour,"
Yes if the frig ran for an hour and the inverter was 100% efficient.
Nor'sea 27
post #7 of 28 Old 08-22-2013
THEFRENCHA's Avatar
I did post recently about how I adapted a $60.00 fridge into my box
I think was " cheap project, let's see them"
Works fine for me since now 4 years
jimgo likes this.
THEFRENCHA is offline
post #8 of 28 Old 08-22-2013
This one?
Low buck projects- Let's see 'em!
Nor'sea 27
post #9 of 28 Old 08-22-2013
THEFRENCHA's Avatar
Page 23 #712
post #10 of 28 Old 08-22-2013
Asleep at the wheel
jimgo's Avatar
Page 23 #712
That's on my list. I have some old dorm-style refrigerators in my basement.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Glacier Bay Refrig Failure stonehill2 Gear & Maintenance 0 09-03-2010 04:02 PM
You think your Refrig is old? deniseO30 Gear & Maintenance 3 06-30-2010 07:26 AM
Climbing Rig Components...? (LONG) backcreeksailor Gear & Maintenance 22 06-16-2009 10:52 PM
Components of a New Boat FritzN Boat Review and Purchase Forum 15 10-24-2006 12:23 AM
Refrig - A/C rleslie Gear & Maintenance 0 03-12-2004 01:17 AM
