Bilge Pump stopped working completely - SailNet Community
post #1 of 8 Old 08-24-2013 Thread Starter
Fau
Possibly improving
Fau's Avatar
The title just about says it all. The automatic bilge stopped about a month ago. I've been switching on the bilge manually whenever necessary. Today it worked for 2-3 seconds on manual and wouldn't work again. I tried for quite a while. Am I most likely looking at a replacement? Thanks.
Fau is offline
post #2 of 8 Old 08-24-2013
Scallywag2's Avatar
Re: Bilge Pump stopped working completely
Did you check the fuse and wiring? I replaced my bilge pump because it did not work and learned I kicked and broke the wire to the battery. That was an expensive replacement that did not need to have happened.
Scallywag2 is offline
post #3 of 8 Old 08-24-2013
snake charmer, cat herder
zeehag's Avatar
check your connections and crimps. also check positioning of the switch..my pumps each have 2 switches--one with metal plate and one breaker. the two have to both be in proper position for auto to function, otherwise you are doing the on and off switch thing by hand.
this is mine in automatic on mode----
this is mine in all off mode.....
formosa 41, cruising tropics
zeehag is offline
post #4 of 8 Old 08-24-2013
Check the float switch as your pump is working on manual its probably the float switch. If its integral as is on some pumps you can wire in a seperate float swtch or take the pump apart and clean it thoroughly though udually when the float switch stops id US so either use a seperate float switch or buy another pump with the integral float switch.
The contacts in the float switch corode and cannot be replaced.
Mike
saltydognl is offline
post #5 of 8 Old 08-24-2013 Thread Starter
Fau
Possibly improving
Fau's Avatar
The manual switch is no longer working either.
Do or do not... There is no try.
Fau is offline
post #6 of 8 Old 08-24-2013
I'd make sure you're getting full power to the unit. If you are, sounds like the unit is toast and needs to be replaced.
Catalina 34
chuck53 is offline
post #7 of 8 Old 08-24-2013
bristol299bob's Avatar
If pump does not come on when switched to manual, start by applying power to the pump directly to see if the pump is burned out. If the pump runs, you'll need to do some detective work tracing faulty wires, crimps, connections, switches. Etc.
Once you have the pump working on manual you'll need to check the float switch. And then the wiring to and from the float switch.
Takes some time and focus is all. If you are the DIY type get in there with a label maker, a DVM and a beer.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #8 of 8 Old 08-24-2013
Islander Yacht Fan
ECS-IB30's Avatar
If you Have the rule switch for auto manual operation check the screw in fuse on the panel. ..
ECS-IB30 is offline
Email notifications stopped working TakeFive General Discussion (sailing related) 4 08-18-2011 02:03 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
TV stopped working Omatako Electronics 6 10-18-2009 03:09 PM
fresh water system stopped working after fill-up Bene505 Gear & Maintenance 26 08-11-2008 02:47 PM
bilge pump not working hd1975 Gear & Maintenance 9 07-17-2008 02:56 AM
