keel fairing - SailNet Community
 3Likes
  • 2 Post By Hudsonian
  • 1 Post By SHNOOL
post #1 of 4 Old 08-24-2013 Thread Starter
keel fairing
I power washed 30 years of anti-foul paint along with the fairing off my lead keel today. Once I get the keel totally cleaned up I was going to put a couple of coats of interprotect on it. Other than fairing out the hull to keel joint, is there really a need to fair a lead keel?
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #2 of 4 Old 08-24-2013
Re: keel fairing
Only if you want to go fast.
SHNOOL and misfits like this.
Hudsonian is offline
post #3 of 4 Old 08-24-2013
4KSB driver.
SHNOOL's Avatar
Re: keel fairing
fairing also gives less edges for stuff to grow... but yeah, it's mostly a foil efficiency thing.
I've read that you can fair before interprotect or after, it really doesn't matter. The smoother you get the final product, the less drag it'll create. Also the better shape the overall keel has, can dramatically improve your point, and/or your sideslip. There is a pretty distinct science to getting the shape right. Depending on the boat make and model you may be able to get a keel template from a place like compu-keels to help improve the shape of your keel in the fairing process.
Oh and if a power washer took your fairing off, then it was likely time to refair anyway.
misfits likes this.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #4 of 4 Old 08-25-2013 Thread Starter
Re: keel fairing
The existing fairing was nothing more than a skim coat.
I never gave any thought to the nooks & crannies that would become habitat for stuff.
Thanks for the info Hudsonian & Shnool!
misfits is offline
keel fairing lofty22810 Gear & Maintenance 3 12-07-2008 04:21 PM
Keel Fairing BarryL Gear & Maintenance 34 03-21-2008 10:15 AM
Marinetex is not ideal for fairing a keel... Sailormann General Discussion (sailing related) 9 04-28-2007 12:43 AM
Keel fairing sailorbri Racing 11 03-14-2007 04:04 AM
Best keel fairing material dargiem Gear & Maintenance 6 09-30-2006 07:07 PM
