How do I get this swivel off? - SailNet Community
post #1 of 6 Old 08-25-2013 Thread Starter
Jiminri's Avatar
I bought a used genuine Bruce anchor and it came with this SS swivel attached. Looks in perfect shape, but I have a chain/rope rode and do not believe I need it and so tried to get it off...but without success.
The big screw in the photo below will not budge. I've tried multiple days of hitting it with PB Blaster. Heating with a propane torch. No luck.
(The other smaller screw to the left in the photo, the one that would attache to the chain, unscrews easily.)
Advice on getting it off?
Or should I just leave it on and use it. If so, I assume I use blue loctite on the small screw. (There is no other way to secure it mechanically.)
Thanks for any advice,
Jim
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #2 of 6 Old 08-25-2013
Re: How do I get this swivel off?
If you intend to reuse and/or save the swivel, try an impact screwdriver. If you don't want to save it, an air driven (or maybe a Dremel) carbide cutting tool would do the job.
AmicaJim is offline
post #3 of 6 Old 08-25-2013
Sounds like you may have to cut it off with a grinder...
Whatever you do, GET RID OF IT... This is a textbook example of why I believe these types of swivels have no place in a proper ground tackle system. And attaching them directly to an anchor stock like that, is an invitation to failure...
The popularity of this sort of setup never ceases to amaze me, there is simply no need for these damn things... And, if one still feels compelled to use a swivel, it should definitely use screw pins that can be moused, and separated from the anchor by a short length of chain...
JonEisberg is offline
post #4 of 6 Old 08-25-2013
overbored's Avatar
Cut it off with an abrasive wheel and though it away. they are a bad idea
"GOLD RUSH" PRINDLE 16
overbored is offline
post #5 of 6 Old 08-25-2013 Thread Starter
Jiminri's Avatar
Thanks guys. Dremels are pretty amazing. A bit of time, 3 carbide cut off wheels later, and the swivel is off. Now just a naked anchor to which I can properly attach a moused shackle.
West River, MD
Jiminri is offline
post #6 of 6 Old 08-25-2013
Whatever you do, GET RID OF IT... ......
The popularity of this sort of setup never ceases to amaze me, there is simply no need for these damn things... .
Jon I hear you, don't have one either, but the shackle on our anchor chain is just big enough around to jam between the cheeks of our anchor roller, so that I have to lift the chain off the roller and get the shank on rather than simply pull it through..
The swivels appealed due to their compact shape but it seemed just another addition point of failure so I've never done it. Any suggestions that would be as secure but with a bit less bulk?
Faster is offline
Swivel Shackle or Not? T37Chef General Discussion (sailing related) 16 08-14-2013 12:36 PM
Streamstay top swivel problem baboon Gear & Maintenance 3 05-24-2013 08:22 AM
Does anyone know of a galvanized anchor swivel that will actually swivel? MedSailor Gear & Maintenance 18 09-04-2012 07:21 PM
$100.00 for an anchor swivel. Worth it? downeast450 Gear & Maintenance 11 04-27-2011 10:30 AM
Triple Anchor Swivel SkipperBob Gear & Maintenance 9 08-24-2008 11:48 AM
