Transom Gelcoat Cracking Repair - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 08-27-2013 Thread Starter
Re: Transom Gelcoat Cracking Repair
Thanks to all for the great info/insights. The info from Rugosa appears spot-on, as there is clearly a seam straight through the middle of this area, and no visible damage from the interior of the hull.
I've sanded through all the visible crazing, and have a couple of thin layers of Evercoat that I'm feathering out now.
I too sprayed gelcoat a few times back in the day, and am thinking I'll probably do so again on this transom. Though I'll have to admit the ease of spraying paint is very tempting...
Again, thanks!
67rway is offline
post #12 of 16 Old 08-28-2013
davidpm's Avatar
I have heard that a preval sprayer works well.
Repairing hull damage the Whaler Way
davidpm is offline
post #13 of 16 Old 10-14-2013
I was thinking of using bon do fiberglass fiber to repair the bow of dads boat any suggestion
Trigger is offline
post #14 of 16 Old 10-14-2013
Senior Moment Member
SloopJonB's Avatar
First, I suggest you think again. Lets see some pics of the damage. Bondo is only a weak filler, not suitable for repairs (or any other purpose on a boat IMHO).
StormBay likes this.
SloopJonB is online now
post #15 of 16 Old 10-15-2013
gelcoat, epoxy, 2 part undercoat; epoxy. Grind through the cracks and re apply, gelcoat.
Zen is a matter of recognizing reality.
desert rat is offline
post #16 of 16 Old 10-15-2013
mitiempo's Avatar
Gelcoat is not the easiest material to apply over epoxy. Many think it is impossible to do successfully. Paint could be a better option.
Brian
mitiempo is online now
Stern/transom gelcoat repair. Tweegs Gear & Maintenance 7 04-27-2011 10:54 AM
Repairing cracking gelcoat Jhoward60 Gear & Maintenance 20 04-09-2009 05:55 PM
Used boat advice - gelcoat cracking yawhunter Boat Review and Purchase Forum 5 05-03-2006 10:59 AM
Need advice re: major gelcoat cracking on 1993 Beneteau F310 martyreiner Gear & Maintenance 5 04-04-2004 06:11 AM
Cracking Gelcoat Dan Dickison Gear and Maintenance Articles 0 12-17-2000 07:00 PM
