furlers and swageless fittings - SailNet Community
post #1 of 3 Old 08-26-2013 Thread Starter
budvar's Avatar
HI!
I have a 25 US Yacht, with a Harken 00AL furler. I replaced the standing rigging, and it
appears the forestay is a couple inches too long. The upper forestay is swageless, the lower forestay is swage fitting.
Rather than go up the mast, remove the forestay, I was wondering, would the 00AL accept a swageless fitting on the lower part of the stay,
in or near the drum assembly?
Thank You so much,
Chris Kilmer
Pasco, Wa.
budvar is offline
post #2 of 3 Old 08-27-2013
casey1999's Avatar
Re: furlers and swageless fittings
Originally Posted by budvar View Post
HI!
Thank You so much,
Chris Kilmer
Pasco, Wa.
I am thinking if you cut off the lower swage fitting and install swage less your forestay length may be a couple inches too short- since swage fittings are a couple inches or more longer than the swageless. I am not sure if the swage less fitting will be too large diameter for it to fit into drum, not familar with Harken- I would contact them directly.
casey1999 is offline
post #3 of 3 Old 08-27-2013
overbored's Avatar
the foil is the very small on the 00AL you may have a tough time if you would need to remove or replace the foil. the lower section should be OK as it contains the turnbuckle and toggles. depends a lot on the length of the turnbuckle and how may toggles you need to make the right length. there are also riggers that can come to the boat and swage on a fitting right on the boat.
"GOLD RUSH" PRINDLE 16
overbored is offline
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
sealing norseman swageless fittings orientalnc2010 Gear & Maintenance 7 01-21-2012 07:04 PM
Harbor Freight 316 stainless swageless fittings JProcter Gear & Maintenance 50 11-13-2009 08:13 PM
Furlers, which one is best for my use? sailbear50 Gear & Maintenance 3 04-11-2009 09:59 AM
Furlers drynoc Gear & Maintenance 0 02-16-2004 04:20 AM
