Cutting an aluminum boom - Page 2 - SailNet Community
 1Likes
post #11 of 11 Old 08-28-2013
Re: Cutting an aluminum boom
I work in the skylight industry. We work with extruded aluminum all day long. A 40 tooth carbide Home Depot blade will work just fine for a couple of cuts. Clamp the boom so its square and tight. Hold tight and take your time. Start the saw and apply wax to the spinning blade. Then lower it thru the material. Do not chop as the name implies. Carefully debur with a file. Be sure to wear goggles.
Don
DonScribner is offline
The Following User Says Thank You to DonScribner For This Useful Post:
davidpm (08-29-2013)
cutting down aluminum masts liveitwell Gear & Maintenance 11 08-04-2013 11:42 PM
Oxidized Aluminum mast and boom dhays Gear & Maintenance 2 08-30-2010 06:11 PM
Cutting out an Aluminum fuel tank..... gtod25 Gear & Maintenance 15 12-10-2008 10:08 AM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 11:33 PM
broken boom mid-boom sheeting problem? somedaypam Gear & Maintenance 15 10-23-2007 06:22 PM
