Cutting an aluminum boom - SailNet Community
 1Likes
post #1 of 11 Old 08-27-2013 Thread Starter
davidpm's Avatar
I have an old boom that came off a Catalina 27'. It got bent and is no longer usable as boom and the boat is long gone anyway.
It is good aluminum however and I could use a couple short pieces for a project I have in mind.
I have a chop (miter) saw that is big enough.
Is their any kind of blade I can put in the chop saw so I can accurately and squarely cut the aluminum extrusion.
If so is their anything I should know other than wear hand and eye protection and go slow.
I'm very comfortable with any kind of wood work but my metal working experience is limited.
davidpm is offline
post #2 of 11 Old 08-27-2013
Capnblu's Avatar
Re: Cutting an aluminum boom
A 60 tooth blade will make a nice cut. I did a 9" mast section this way.
sawingknots likes this.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
The Following User Says Thank You to Capnblu For This Useful Post:
davidpm (08-27-2013)
post #3 of 11 Old 08-27-2013
I use the above and some cutting oil to make the blade stay sharp longer.
Rebuilding The S/V Kompira
SOVT is offline
The Following User Says Thank You to SOVT For This Useful Post:
post #4 of 11 Old 08-27-2013
Tartan 27' owner
CalebD's Avatar
And if you want to save your nice 60 tooth blade for wood they do make "cut off wheels" for aluminum. A good 60 tooth saw blade is not cheap.
ALUMINATOR Cut Off Wheels for Aluminum | Rex-Cut Abrasives
No affiliation.
Home despot probably carries an equivalent product.
Everybody has one:
CalebD is offline
The Following User Says Thank You to CalebD For This Useful Post:
post #5 of 11 Old 08-27-2013
Wax candle help the cut and prevents spauling on the teeth. Otherwise just like wood.
Capt Len is offline
post #6 of 11 Old 08-27-2013
Tartan 27' owner
CalebD's Avatar
What is it with Catalina 27s & 30s with the bent booms?
Is it the mid boom sheeting?
A Catalina 30 at our club bent it's boom while racing in 20+ knots a few years ago; accidental jibe.
Everybody has one:
CalebD is offline
post #7 of 11 Old 08-27-2013 Thread Starter
davidpm's Avatar
In our case the OP had re-rigged the sheet from a three point connection to a single connection and we didn't know enough at the time to fix it.
It was already bent a little so was guaranteed to fold.
We just didn't know enough at the time.
davidpm is offline
post #8 of 11 Old 08-27-2013 Thread Starter
davidpm's Avatar
How do you do that exactly.
Rub it on the teeth before each cut?
davidpm is offline
post #9 of 11 Old 08-27-2013 Thread Starter
davidpm's Avatar
No affiliation.
That looks perfect. I would prefer to use the miter saw rather than the angle grinder to get a better cut.
I see if I can get a wheel that will work on the bigger saw.
davidpm is offline
post #10 of 11 Old 08-28-2013
overbored's Avatar
they make the 14" aluminum cut off wheel for a metal cutting chopsaw
"GOLD RUSH" PRINDLE 16
overbored is offline
cutting down aluminum masts liveitwell Gear & Maintenance 11 08-04-2013 10:42 PM
Oxidized Aluminum mast and boom dhays Gear & Maintenance 2 08-30-2010 05:11 PM
Cutting out an Aluminum fuel tank..... gtod25 Gear & Maintenance 15 12-10-2008 09:08 AM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 10:33 PM
broken boom mid-boom sheeting problem? somedaypam Gear & Maintenance 15 10-23-2007 05:22 PM
