Wind Vane Calibration - Page 2 - SailNet Community
post #11 of 13 Old 12-03-2013
Re: Wind Vane Calibration
I think true wind calculations shown by instruments are usually done based on speed through water rather than GPS speed over ground, because wind speed over water in relation to your keel is what moves your sailboat.
However, for apparent wind speed calibration calculations it seems easier to get current out of the equation and pretend that I am driving a car with mast over seabed with GPS giving the speed over ground. It would be similar to taking off the wind transducer and mounting it on top of my van. (probably too much trouble to do in reality) and doing the test this way.
I'm hoping the once the apparent wind is properly calibrated the true wind speed calculations will take care of them selves over water with current included.
Maybe I am over thinking it.
lumelind is offline
post #12 of 13 Old 12-05-2013 Thread Starter
ThirdCoastSailor's Avatar
Lumelind,
I'm guessing my unit is reading high by about 20%. It reads 30 knots in what I think is about 25 knots.
TCS
ThirdCoastSailor
s/v Memento Vivere
'Remember to Live!'
Catalina 380
ThirdCoastSailor is offline
post #13 of 13 Old 12-05-2013
Dog Ship's Avatar
Ours is out too, reads a little high maybe 10-15%. No big deal as it is the only wind speed indicator onboard. It's an older Datamarine unit and it has no calibration adjustment.
It is what it is, so you become accustom to it. Fifteen knots of wind is a relative reading that you take as is. What the actual wind speed is doesn't really matter so long as you know your boat and instruments accordingly.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
Used Aries Wind Vane -- Should I go for it? obelisk Gear & Maintenance 17 02-02-2013 03:41 PM
wind vane? freedom40 Introduce Yourself 0 08-13-2012 06:01 PM
looking for a used wind vane any help obiec Gear & Maintenance 18 02-01-2012 07:56 AM
Pendulum wind vane -V- auxiliary rudder vane SimonV Gear & Maintenance 7 11-11-2007 08:15 PM
wind vane musolmar Learning to Sail 7 09-01-2004 11:40 AM
