CNG stove and microwave - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 08-28-2013
Re: CNG stove and microwave
When we bought our Catalina 34, we found a good space to mount a small microwave. Seems like it is a .6 sq. foot model. Takes up very little space and it does get used.
We also have CNG. It is a little bit of a pain to get it refilled since there are so few places as compared to propane, but I'll never make the switch. Making the switch is way more trouble than it's worth.
Catalina 34
chuck53 is online now
post #12 of 16 Old 08-28-2013
Stu Jackson's Avatar
We have CNG and a microwave (ours is under the galley sink where the drawer used to be for those who know C34s). We have a 1500 watt Freedom 15 inverter charger. We have a backup CNG tank on board, and CNG is available right down the street from us as well as one place in the California Delta that we know of.
The whole issue of CNG vs. propane is soooo overdone and old...
If you are out of an area that has easily available CNG, then the switch is easy. Call Seaward, give them the serial # of your stove (open the top after taking off the burner pot holders) and you'll get everything you need. Build a tight vented propane box, or stow the cans on deck somewhere with a watertight and airtight entry into the boat with the hose, buy a solenoid and be done with it. WM Advisors have a good writeup of what you need.
Good luck, it's doable either way.
PS - that backup CNG is something that has, well, saved our bacon, more than once! On our C34 it's under the port settee forward with a hole cut into the wall to the V berth under the drawers, to make it fit.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #13 of 16 Old 08-28-2013
Originally Posted by Stu Jackson View Post
We have CNG and On our C34 it's under the port settee forward with a hole cut into the wall to the V berth under the drawers, to make it fit.
Our tank is under the seat in the aft cabin. Fits perfectly and it's right next to the stove. Couldn't be a more perfect location.
Catalina 34
post #14 of 16 Old 08-28-2013
Chuck, our BACKUP cylinder (reread my post) is under the port settee. The main tank for the stove is where yours is.
post #15 of 16 Old 08-28-2013
Got cha. We don't use our stove enough where we need a back up tank, but That's a good place for it.
Catalina 34
post #16 of 16 Old 08-28-2013
outbound's Avatar
Hadn't thought of that.good point. Thanks
s/v Hippocampus
Outbound 46
outbound is offline
Microwave and gen. nauticalrich General Discussion (sailing related) 11 10-23-2012 01:13 PM
2 or 3 burner stove and "why would I want a microwave...?" F15EWSO Cruising & Liveaboard Forum 26 06-12-2011 08:42 AM
12v microwave Reddirt Gear & Maintenance 37 12-06-2010 09:56 PM
Microwave on the PSC 34 cvsheppard Pacific Seacraft 4 11-20-2008 10:56 AM
Microwave tdw Living Aboard 10 05-01-2007 10:06 AM
