Kiwigrip - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 08-29-2013 Thread Starter
Darlene
Re: Kiwigrip
Thank you for the info. How big an area did you cover approximately and how much did you use. I'm thinking maybe I need to buy over and above what they recommend?
Dmbak is offline
post #12 of 16 Old 09-02-2013
Re: Kiwigrip
I'm applying it to my boat now and am really happy with it. Once you start rolling it, it will set up quickly and if it's hot, you should work fast. As soon as it is to the point where you like the way it looks, pull the tape off.
I bought white, but decided it would be to bright so had it tinted at a local paint store to a light tan, came out really nice. Since it isn't their standard base, they won't guarantee it comes out exactly like the sample but it will be really close.
I bought a couple of their rollers, but at $25 they are expensive. Went to Home Depot/Lowes and got orange texture rollers with "loopy-goopy" loops, work just as well at $6. Sometimes the rollers are in the paint section, sometimes in the drywall section.
It is the consistency of mayonase, I scoop globs on an area and spread it with a notched trowel from the home improvement store, something like 3/16 notches, it was the finest I could find there. How thick you spread it contributes to how agressive the tread will be. If it is too agressive just keep rolling it pick up excess and then roll it on the next adjacent area you plan to apply it to. If it isn't as agressive as you like I've put some in a paint tray to get it on the roller and then gone back over an area after it was dry and built it up more.
Keep a bucket of water to put your tools in while you aren't using them, it will set up on them quickly.
Dmbak likes this.
TomN is offline
The Following User Says Thank You to TomN For This Useful Post:
Dmbak (09-02-2013)
post #13 of 16 Old 09-02-2013 Thread Starter
Darlene
Smile Re: Kiwigrip
Wow! Thank you so much for all the helpful and money saving tips! I can't wait to get started on my project. I won't be heading down to the boat until mid October but at least now I will have everything ready to go when I get there. Everyone has been most helpful. I have a feeling I will be seeking advice on SailNet again and again!:
Dmbak is offline
post #14 of 16 Old 09-02-2013
No more curry buffets
Ritchard's Avatar
Re: Kiwigrip
I did my decks and cabin top in the spring with Kiwigrip mad it came out great. As with everything tomdomwith painting, the results are all in the prep. I washed, abraded, washed again, then solvent washed to get the best adhesion. Now that I see how tenacious a bit of spray is on non-prepped areas, maybe I needn't have bothered being so thorough.
Careful masking is crucial to good results. A helper is pretty well necessary. Slop it on with a small notched trowel and float it out before rolling. Different textures/grippiness can be achieved by varying the a punt of product and roller pressure.. Pull the masking tape right away. Kiwigrip has a chart for heat and humidity, well worth looking at.
I was lucky to have had one perfect day this spring, warm, not hot, medium humidity, we just roared through the application on my 32 footer.
I also did a custom sort of sandy tan color at the local paint shop. The contrast with my freshly painted cabin top and cockpit is fantastic.
It will cover roughly what the can says, I think it's 80 sq ft per gal?
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #15 of 16 Old 09-02-2013
baDumbumbum
bobmcgov's Avatar
Re: Kiwigrip
Second all the positive reports here. We got our decks a bit too stippled (hot day, working too-large sections), but it sure is grippy! For the cockpit seats and coaming tops, we spread a thinner layer and rolled it with a cheap foam roller cover; result is a lightly suede texture that is easy on clothes and skin but MUCH safer than the molded non-skid was. It does show dirt. Good product, good customer service from the West Coast distributor. When the time comes, our 30'er will be getting KG. Not even considering anything else.
To prevent unused KG from hardening in the can, decant into smaller jars & top with Bloxygen or propane. It's super-easy to touch up any gouges.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #16 of 16 Old 09-03-2013
Break, curse, fix, repeat
bwindrope's Avatar
Re: Kiwigrip
I'll give another endorsement. Did all my decks and it worked great. Used the boat heavily this summer and the Kiwi showed no ill effects. Having tried or used other products so they may be great also, but I can say for sure that Kiwi grip did the job I wanted.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
Technique for Smoothing KiwiGrip andrewalexander General Discussion (sailing related) 6 08-01-2013 07:45 AM
Kiwigrip advice needed SloopJonB Gear & Maintenance 36 02-27-2013 12:13 PM
Non skid - Kiwigrip need some input patrscoe General Discussion (sailing related) 5 07-01-2011 08:11 AM
KiWigrip, too good to be true? deniseO30 Gear & Maintenance 9 06-04-2010 01:28 PM
kiwigrip photos at last nightowle Gear & Maintenance 15 11-19-2008 08:52 PM
