Smoke and CO2 detectors - SailNet Community
 1Likes
post #1 of 14 Old 08-29-2013 Thread Starter
Dave_E's Avatar
Hi All,
The Allmand 31 is mine! The insurance company gave me 45 days to comply with recommended repairs/upgrades from the survey, 2 of which were smike detector and CO2 detector. No big, I'm good with that. I've researched and found we don't have "marine industry standards" for these items and feel OK getting them from Home Depot, but where to install them... never thought about that before. Really can't see punching holes in the overhead so the smoke detector is on the ceiling like in the house. Any suggestions?
Dave
Dave_E is offline
post #2 of 14 Old 08-29-2013
The most female moderator
Donna_F's Avatar
Dock
Re: Smoke and CO2 detectors
They make combination units so you only have to install one.
Diesel engines can leak a small amount of Co2 so you might consider placing it fairly near the engine and galley.
Congratulations!
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 14 Old 08-29-2013
overbored's Avatar
I think it is a CO detector that they require and they do make them for marine use
Carbon Monoxide Detectors from Fireboy-Xintex
http://www.fireboy-xintex.com/smoke-alarm.htm
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 14 Old 08-29-2013
Donna_F's Avatar
Dock
They do make marine versions. Unlike fire extinguishers, there is no legal requirement for installing the marine version rather than one you would use in your home. I'm not saying they aren't built differently.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #5 of 14 Old 08-29-2013
Originally Posted by Dave_E View Post
Hi All,
Dave
"Sticky" sided Velcro?
Paul T
dabnis is offline
post #6 of 14 Old 08-29-2013
tommays's Avatar
They should really be on a 24 hour 12 volt circuit and they kind of fall under UL 2034
I fell it is a small investment and have a SAFE-T-ALERT unit
Marine Operating Specifications
UL Listed to UL 2034-2005 for Marine use, including March 8, 2007 revisions. Meets ABYC A-24 recommended standards.
Marine environment tested for salt water spray, cooking fumes, shock, humidity, temperature extremes, vibration and corrosion.
Power 12 vDC, operational range 8-16 volts.
Micro Current Technology: 60 milliamp (.06 amp.) current draw.
Widest Operational Temperature Range Available:-40F to +158F
(-40C to +70C).
Relative Humidity: 15% to 93%.
Confirmation Circuit: Yes - Circuit reconfirms CO levels before alarming.
Audible Alarm: Minimum 85dB @ 10 feet.
Case Dimensions:
Model 60-541 Surface Case - 5.5"W x 3"H x 1.3"D.
Model 60-542 Flush Case - 6.5"W x 3.5"H x 1.25"D.
Weight: 60-541 / 542 = 0.43 lb.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 14 Old 08-29-2013
Paul T
That is what I use. Mount them in the center of the main cabin.
LinekinBayCD is offline
post #8 of 14 Old 08-29-2013
Remember you're a womble
PaulinVictoria's Avatar
Double-sided sticky tape (or velcro, but I don't think you're going to take it down much, a battery one lasts for years) for mounting. Remember that smoke goes up high, CO, CO2 (and propane if applicable) go down low.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #9 of 14 Old 08-29-2013
Double-sided mounting tape, and a BIG patch of it, will work. Most "Velcro" adhesives will release on a hot summer day.
Also be aware the all of the inexpensive smoke detectors are "ionization" types that need to be thrown out, completely, in five years. They tend to die around the 5-7 year range as the ionization chamber gets covered in crud internally, and if you are in a salt air location, I'd expect it to fail even sooner. So look for a "dual" detector, because the photocell type are slower on some fires, faster on others, and the dual detector can sometimes give you a full 15 minutes of additional warning. Figure $30-50 for a dual detector, and keep the CO detector separate. Those also fail over time.
If you aren't really sure of the difference between CO and CO2...take a basic boating safety course with the US Power Squadrons (USPS) or similar. You'll appreciate some of the safety tips, and probably get an insurance discount when you renew.
hellosailor is offline
post #10 of 14 Old 08-30-2013
You definitely want a marine CO detector, not Home Depot, wired into 12V.
The domestic ones alarm when they reach a threshold, while the marine ones calculate an actual dose over time (time-weighted average). This means that a domestic one is constantly going off, when it gets a whiff of CO from your engine or someone else's. My marine one never triggers accidentally.
Donna_F likes this.
MarkSF is offline
radar detectors rickmc Gear & Maintenance 20 11-26-2009 04:50 AM
Radar Detectors at Sea? rjg23 Gear & Maintenance 5 04-01-2009 12:24 AM
propane Gas detectors mcagney Gear & Maintenance 0 01-15-2004 08:57 AM
Gas detectors... uri Gear & Maintenance 0 07-18-2002 01:29 PM
Wind speed detectors BiscuitBandit General Discussion (sailing related) 3 11-05-2001 04:05 AM
