spreader bolt mast issue - SailNet Community
post #1 of 8 Old 08-30-2013 Thread Starter
Forward bolt on spreader has pulled out of mast and started a tear in the aluminum. Evidence of some stress on the other bolt holes as well. Any ideas or suggestions from anyone who has observed similar would be greatly appreciated. One suggestion from local marina was to machine an aluminum spreader bracket to replace the stainless and welt it directly to the mast.
20130828_164123 starboard 1 b.jpg   20130828_164154 port b.jpg   20130828_164031starboard 2 b.jpg
cmuz is offline
post #2 of 8 Old 08-30-2013
azguy's Avatar
Re: spreader bolt mast issue
I would think that's pretty serious and needs immediate attention, I'll be interested to read some suggestions...
azguy is offline
post #3 of 8 Old 08-30-2013
Kynntana (Freedom 38)
gamayun's Avatar
I'll be interested in hearing about this, too. It is curious that it is being held by 2 screws and 1 bolt.
gamayun is offline
post #4 of 8 Old 08-30-2013
OPossumTX's Avatar
DO SOMETHING! If you don't, your mast is about to get very noticably shorter.
OPossumTX is offline
post #5 of 8 Old 08-30-2013
manatee's Avatar
Anything causing unusual forces or stress on the shrouds & spreaders?
Barring a new mast, could you make a boot or collar to wrap around the mast to reinforce it, attach spreaders to boot? Like this:
Split Steel Conduit
This would be *temporary*, but better than nothing. I'd be worrying about the mast failing at the bolt line.
The mast needs to be reinforced at spreader attachment points, and probably other attachments.
Can they saw the mast in half at the failure and install a reinforcing sleeve, then put it back together? An extra pound or two aloft is better than having the whole rig come down on your head.
Do you have spreader support lines? They attach about halfway between mast & spreader tip, attach to mast at about 45-degree angle, distribute loads & keep spreaders from drooping.
Good luck.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #6 of 8 Old 08-30-2013
You may wish to replace the two spreader brackets with a SS collar and continuous spreader. Check with rig manufacturer. These failures are common and often the spar maker has developed a retrofit.
Hudsonian is offline
post #7 of 8 Old 08-30-2013
continuous spreader is the best solution.
The mast can be reinforced by riveting curved plates on both sides of the mast. No need to cut the mast into two pieces first, most probably you will have a hard time to find a profile that will fit inside the mast.
Have a look at this thread Cracked Mast at Spreader - SparTalk
knuterikt is offline
post #8 of 8 Old 08-30-2013
Older posts on the subject: repairing cracked mast with welding
Seaduction is offline
Triple Spreader Mast Rustyf General Discussion (sailing related) 5 12-01-2011 01:17 AM
Mast, spreader, shroud design, help Talisman66 Gear & Maintenance 1 11-23-2008 04:41 AM
Cal 20 Keel Bolt Issue sailorlinus Cal 3 11-12-2008 05:48 PM
Keel bolt issue gray_williams Gear & Maintenance 8 12-05-2003 07:23 AM
