Can I just use Naptha instead of Epifanes thinner - SailNet Community
 5Likes
post #1 of 15 Old 08-30-2013 Thread Starter
It seems it is the same thing but more expensive. Just wanted to make sure, cuz I dont mind saving a buck but dont want to skimp either. Oh I'm talking about varnishing brightwork in case it was not obvious.
abrahamx is offline
post #2 of 15 Old 08-30-2013
Re: Can I just use Naptha instead of Epifanes thinner
Assuming that the varnish is an alkyd modified phenolic, or better yet straight phenolic ($$)
than I can think of no better solvent than VMP Naphtha. Thinners like kerosene and the like are dilutents. There's a difference.
Dick
Flybyknight is offline
post #3 of 15 Old 08-31-2013
I believe Epiphanes thinner is mineral spirits, which does not evaporate as quickly as naphtha. That could be important to flow and settling. If you are varnishing at all, it usually suggests you would like it to look nice. I would not cut corners. Getting varnish to look good is an art as it is.
Jeanneau 54DS
Minnewaska is offline
post #4 of 15 Old 08-31-2013 Thread Starter
Yea, thats what I've been using. I have been cleaning my brushes with it also. Just realized I should just use something different for cleaning my brushes and just use epifanes with epifanes.
abrahamx is offline
post #5 of 15 Old 08-31-2013
bljones's Avatar
Use foam brushes and toss 'em after each coat.
Seaduction and Rhapsody-NS27 like this.
It's 5 o'clock somewhere:
bljones is offline
post #6 of 15 Old 09-01-2013 Thread Starter
I used a foam brush on my last coat and got a bunch of bubbles so I figured to heck with the foam.
abrahamx is offline
post #7 of 15 Old 09-01-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I used Epifanes with basic mineral spirits from the hardware store on a couple handrails. They turned out pretty good. Also go with what bljones said with the foam brushes. I bought a box of them. When they start to get thick on the brush, toss them and get a fresh one.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #8 of 15 Old 09-01-2013
Right on!
The Following User Says Thank You to Flybyknight For This Useful Post:
abrahamx (09-01-2013)
post #9 of 15 Old 09-01-2013
I did this job with foam brushes. I wasn't a believer tills tried. Final coats took about 5% thinner to flow off brush. Done over wnter, indoors, 70 degs and dry. Brushes might have been marginally better, but ou wold have to look hard.
Perfection Plus
Jeanneau 54DS
post #10 of 15 Old 09-01-2013
bljones's Avatar
If you're getting bubbles, you may have aerated the varnish by overstirring/shaking it, you are underthinning, brushing too quickly, and most likely not loading the brush fully when you first start. Let the fresh brush sit in the varnish until the foam is saturated, then clean off the excess, and go to work.
bljones is offline
Lanocote thinner? downeast450 Gear & Maintenance 2 06-16-2011 04:53 PM
kerosene/thinner? wiseleyb Gear & Maintenance 18 02-12-2009 04:04 PM
Lacquer Thinner - Safe around fiberglass? Finallybuyingaboat Gear & Maintenance 1 10-12-2007 03:24 PM
Prep question for Epifanes Varnish (also which one) geary126 Gear & Maintenance 9 05-11-2007 12:12 PM
Shelf life of Cetol/Epifanes Jonathan316 Gear & Maintenance 11 07-17-2004 06:45 PM
