iPad GPS accuracy? - Page 2 - SailNet Community
post #11 of 24 Old 08-31-2013 Thread Starter
Re: iPad GPS accuracy?
No. Looks like the wifi only units don't have GPS.
and if the cellular ones need cellular service for their GPS to work, I don't
think that is very valuable for navigation purposes.
groundhog is offline
post #12 of 24 Old 08-31-2013
turophile
The 3G/4G units do not need cell service to work.
mr_f is offline
post #13 of 24 Old 08-31-2013
scratchee's Avatar
Originally Posted by groundhog View Post
...and if the cellular ones need cellular service for their GPS to work...
That's why I wrote my first post the way I did. GPS has nothing to do with cellular service. Some devices use a cellular location technique to augment GPS (for example, to provide rough location if you are inside where GPS doesn't work,) but GPS itself will never require anything but a GPS receiver.
Sorry about your mis-matched specs. Maybe you could get a bluetooth GPS receiver to make up the difference. Or maybe Apple would let you return it?
scratchee is offline
post #14 of 24 Old 08-31-2013
ebs001's Avatar
My iPad GPS puts my position within a couple of feet most of if not all the time. I know this because it shows me in the exact spot in a slip at a marina. I have the Garmin app and love it.
ebs001 is offline
post #15 of 24 Old 08-31-2013
The cellular+wifi models have a full GPS. It is called assisted GPS only because it can use the phone towers to acquire an initial position more quickly. This is better, not worse than a conventional GPS system. It works fine outside cellphone range.
Having said all that there is a difference between different GPS units. The quality of the GPS chip and the antenna design do make a difference. I have a dozen GPS units on board and there are noticable variations in the data quality.
I would rate the iPad GPS as reasonably good, but there are better units.
One interesting feature is that it is also a GLONASS receiver
noelex77 is offline
post #16 of 24 Old 08-31-2013
old guy :)
rikhall's Avatar
I have a wifi only iPad 4 and use this GPS and it seems to be very accurate!
Looks like this:
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #17 of 24 Old 08-31-2013 Thread Starter
I ran an interesting experiment which I may do some more of...
Took my iPhone 4, put in airport mode, turn on wifi.
Now it should be the same as my ipad wifi.
The iPhone mapping performance then got worse.
I should next cut off all comm on both and see what they do
post #18 of 24 Old 08-31-2013 Thread Starter
If they really do have full GPS, they should still make an accurate blue dot.
post #19 of 24 Old 09-01-2013
Originally Posted by scratchee View Post
The only real variable (other than special techniques available only to the military) is the sensitivity of the receiver;
Not quite true - another major variable is whether your recieiver is WAAS-enabled.
MarkSF is offline
post #20 of 24 Old 09-01-2013
glymroff's Avatar
Location: Winter/Spring - Sailing, Summer/Fall - Vermont
I have a IPAD2 wifi. It does NOT have GPS. It uses cell towers for locale. This is very accurate if you are lake or potentially very close coastal. I've used it 2+ miles off shore.
However, if there isn't a strong enough signal or you are in a dead zone, then it barely works for location based services.
The Dual or Bad Elf or Bad Elf Pro solve this. Google them. They range from 65-180 bucks.
I'm not sure if the newer IPADS have GPS chips or not in the WIFI only units. A quick (lol) check of the apple web site would verify this or not.
Happy Sailing... :-)
glymroff is offline
The iPad thread! who uses an iPad for sailing? NewportNewbie Apps & Authors 71 02-10-2014 03:36 AM
GPS Accuracy and Price Mark Sloan Gear and Maintenance Articles 0 10-05-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
