Watertight blind bolts? - Page 2 - SailNet Community
 4Likes
post #11 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
Re: Watertight blind bolts?
Brilliant!
Graham
Originally Posted by knuterikt View Post
Instead of using a pole you could thread a thin line through one hole front to back, diagonally across the back side of the plate and back to front.
use an fish tape to pull both ends of the line through the holes in the boat, and pull the plate into place.
When you have inserted the two bolts in the free holes you can just pull the line out and insert the two remaining bolts.
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #12 of 24 Old 09-03-2013
JimsCAL's Avatar
I see no problem with a watertight access in the propane locker. One of those round things with an O-ring seal.
An alternative to a nut is to tap a thick backing plate.
JimsCAL is offline
post #13 of 24 Old 09-03-2013
Propane locker's need to be gas-tight for a reason - rules or no rules.
How would you ensure the integrity of the access cover?
By testing..
knuterikt is offline
post #14 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
Thanks guys,
I will try the string and backing plate and let you know how it goes.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #15 of 24 Old 09-03-2013
I would cut an access panel and then just epoxy it back in. Its inside a locker.
Jeanneau 54DS
Minnewaska is offline
post #16 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
Plan B.
Thanks,
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #17 of 24 Old 09-06-2013
manatee's Avatar
Could you use blind nuts on the plate?
Atlas brand blind threaded rivet nuts and studs
Blind Rivet Nuts - Bolt Products, Inc.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #18 of 24 Old 09-06-2013
Asleep at the wheel
jimgo's Avatar
Manatee, those are really neat! I've never seen something like that before. I forgot to look at how thick of a sheet they could handle. Something like that into a pre-drilled backing plate would be pretty cool. I wonder how water-tight they would be, or how best to seal it. It seems like removal would be difficult for rebedding purposes.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #19 of 24 Old 09-06-2013
manatee's Avatar
Jim,
You might not want to remove them, or upset them either. Sometimes you make them a permenent part of the project. Use these instead of tapping holes in a plate, for example. It depends on the project. When I was using them to make custom wheelchair gear, I didn't always use them according to maker's directions. (Sometimes I put them on 'backwards' to get a particular assembly to work.) I think you could bed them with butyl or epoxy. In a water environment it would be important to match metals: stainless bolts == stainless nuts. I'd Loktite the bolts in any location subject to vibration, or hard to inspect. Once you have them, you can find all kinds of things to use them for. We used to order kits with different sizes, sort of like a pop-rivet kit. Try them, you'll like them.
Gary
jimgo likes this.
~~Dylan Winter,
manatee is offline
post #20 of 24 Old 09-07-2013 Thread Starter
GrahamO's Avatar
Thanks Manatee,
I had not come across these before, or at least I did not know what they were when I did..... I would still need to get the plate into place but that would be relatively easy. There are plenty of stainless ones available and most of the waterproofing effort needs to be on the outside.
Graham
Originally Posted by manatee View Post
Jim,
Gary
Graham and Janaki
Bristol 38.8
GrahamO is offline
Float Around Toronto: Watertight deals - National Post (blog) NewsReader News Feeds 0 08-06-2011 03:40 PM
Need a watertight wire splice oomfh Gear & Maintenance 6 04-29-2011 10:00 PM
Watertight Cockpit Lockers tager General Discussion (sailing related) 4 03-25-2010 08:30 PM
Watertight seal on thru-bolt deck hardware??? SiXeVeN Gear & Maintenance 12 09-14-2009 09:22 AM
