Watertight blind bolts? - SailNet Community
 4Likes
post #1 of 24 Old 09-01-2013 Thread Starter
GrahamO's Avatar
I need to mount a couple of plates on my transom for my davits. One of them is in a REALLY inaccessible location from the inside.
Does anyone know of a blind bolt or anchoring system that:
1. Will be strong enough
2. Can be made watertight
3. Will not corrode?
I know - big ask.... Failing this I need to find a very small boat ferret.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #2 of 24 Old 09-01-2013
One of None
deniseO30's Avatar
Re: Watertight blind bolts?
there are SS toggle bolts
My last project!
deniseO30 is offline
post #3 of 24 Old 09-01-2013 Thread Starter
GrahamO's Avatar
Thanks Denise,
I should have provided more info. This is a high shear load and toggle bolts can displace relatively easily in shear due to the oversized hole. I was wondering about putting a sleeve on the bolt to fill the void but I would prefer an engineered solution to my bodge....
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #4 of 24 Old 09-03-2013
Graham
I have not seen that type of bolts, but I read about a neat trick somewhere.
The idea is to make a backing plate with integrated attachment's.
The author used a thin line attached to a threaded hole in the center of the plate and a extra hole in the boat to pull it into place.
When in place a countersunk screw where used to keep the backing plate in place during installation (and left there).
There are several ways you could do this, using the outside plate as template.
I have successfully glued large washers and nuts onto plywood with thickened epoxy, use bolts to keep the washer & nut in place and build up a large cone of epoxy around the nut/washer apply some grease to the bolt threads to avoid it getting stuck (or avoid putting epoxy over the threads .
You can also attache the bolts to the plate i a similar way.
If you prefer backing plate of metal you could weld the bolt / nut onto the plate or cut threads directly into the plate (you need some thickness in the plate to cut threads).
knuterikt is offline
post #5 of 24 Old 09-03-2013
Graham
Add an access panel opposite the plate?
sailorboy15 likes this.
LinekinBayCD is offline
post #6 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
thanks K,
I actually have a metal backing plate and the idea of mounting the nuts to it is a really good one. I'm sure I can find a way of putting the plate on some kind of pole.
At the very least it will be much easier to find in the bilge when I drop it.......
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #7 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
I wish.....
It is in the upper stbd corner of the transom behind the propane locker so the only options for an access panel are the transom, the deck or the hull. I'm not keen on any of those.
There is actually a fairly large volume on my boat under the propane locker that is entirely inaccessible without taking out either the steering gear or the engine - not good.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #8 of 24 Old 09-03-2013
thanks K,
Graham
Instead of using a pole you could thread a thin line through one hole front to back, diagonally across the back side of the plate and back to front.
use an fish tape to pull both ends of the line through the holes in the boat, and pull the plate into place.
When you have inserted the two bolts in the free holes you can just pull the line out and insert the two remaining bolts.
GrahamO likes this.
The Following User Says Thank You to knuterikt For This Useful Post:
GrahamO (09-03-2013)
post #9 of 24 Old 09-03-2013
I wish.....
It is in the upper stbd corner of the transom behind the propane locker so the only options for an access panel are the transom, the deck or the hull.....
I'm sure we're not picturing the situation, but this begs why you can't put an access panel in the back of the propane locker.
Jeanneau 54DS
Minnewaska is offline
post #10 of 24 Old 09-03-2013 Thread Starter
GrahamO's Avatar
you are picturing it fine. Isn't it illegal to put an access panel in a propane locker????
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
Float Around Toronto: Watertight deals - National Post (blog) NewsReader News Feeds 0 08-06-2011 03:40 PM
Need a watertight wire splice oomfh Gear & Maintenance 6 04-29-2011 10:00 PM
Watertight Cockpit Lockers tager General Discussion (sailing related) 4 03-25-2010 08:30 PM
Watertight seal on thru-bolt deck hardware??? SiXeVeN Gear & Maintenance 12 09-14-2009 09:22 AM
