Temp seal for teak deck caulking - SailNet Community
post #1 of 4 Old 09-01-2013 Thread Starter
I have a few places that are separated and need to be recalked. However, teak deck systems, which I've been using, takes 24 hrs to dry. I need a window of non-sailing dry time. They don't come around often.
Any trick to temporarily seal it? I'm reluctant to dig up the caulk and use faster drying silicon, as it may be a nightmare to get it out and do right later. I wold slap some tape over it, but worried about glue residue.
Stumped.
Jeanneau 54DS
Minnewaska is offline
post #2 of 4 Old 09-01-2013
aeventyr60's Avatar
Re: Temp seal for teak deck caulking
Why not use the standard one part teak deck seam sealant? Worked for me until I ripped those darn decks off....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #3 of 4 Old 09-02-2013 Thread Starter
That's what I do use, it just takes 24 dry hours to set up properly.
Jeanneau 54DS
post #4 of 4 Old 09-02-2013
aeventyr60's Avatar
Sorry was thinking the Teak deck Sysytem was that nasty 2 pot stuff. I think the sika brand sealer cured a bit faster...
Hull Deck joint caulking RossC32 Gear & Maintenance 5 09-11-2011 02:38 PM
Help on the best caulking for deck attachments. 4play Gear & Maintenance 4 03-17-2009 01:59 PM
Teak Decks & Grinding the caulking down dsbentley Gear & Maintenance 4 10-29-2008 09:33 PM
teak caulking question cbayermd Gear & Maintenance 7 04-14-2008 01:30 PM
Teak Deck Caulking Leaks dsbentley Gear & Maintenance 3 03-13-2007 08:49 PM
