Anyone used silicone wet exhaust hose? - SailNet Community
post #1 of 5 Old 09-02-2013 Thread Starter
I recently replaced my exhaust mixing elbow (2QM15), and I'm having trouble fitting up the short length of 2 inch hose between the elbow and the waterlift muffler. Basically, because the run is so short (about 12 inches), the hardwall EPDM hose that I'm using is too stiff to force onto the fittings.
I'm thinking about trying some softwall hose instead, since the run is so short, and relatively straight. But I've been reading that silicone rubber lasts much longer, and is easier to remove from the connections when necessary (the rubber hose was welded with rust to the elbow that I removed). The silicone hose costs about twice as much, but with this short of a piece, the difference is manageable.
Has anyone had experience with silicon hose? How is its flexibility, compared with EPDM hose?
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is offline
post #2 of 5 Old 09-02-2013
Re: Anyone used silicone wet exhaust hose?
I've never used silicone hose but I've also heard good things about it.
I do know not to use hard wall hose if you can avoid it. The wire inside will rust and cause it to fail sooner than a similar soft wall hose. Sometimes you need to make a bend that would kink a soft wall hose, then you have to use hard wall, but if you can, always use soft wall hose.
hopcar is offline
post #3 of 5 Old 09-02-2013
When I replaced the original hose with blue silicone exhaust hose from the exhaust elbow to the muffler on my 2GM it was very easy to handle. As I recall, it was a bit pricey but very satisfactory.
Hudsonian is offline
post #4 of 5 Old 09-07-2013 Thread Starter
Update: softwall silicone hose is nice stuff, but kinks with the slightest bend. Won't work for my application, which requires a slight S shape. Ordered some corrugated wire rewound silicone hose. (This is getting expensive).
Sent from my iPad using Tapatalk - now Free
Rusty123 is offline
post #5 of 5 Old 09-08-2013 Thread Starter
Another update: hard wall silicone pipe isn't much more flexible than (new) hardwall rubber hose, but it slides over the fittings much easier.
Rusty123 is offline
why did exhaust hose submerge? alman General Discussion (sailing related) 19 05-31-2011 02:51 AM
exhaust hose size jr438234606 Gear & Maintenance 3 04-23-2011 04:18 PM
Wet Exhaust Hose 1970Columbia34 Gear & Maintenance 1 03-09-2009 08:40 AM
Leak Around Exhaust Hose ArgleBargle Gear & Maintenance 1 10-19-2007 12:23 AM
Leaking Exhaust Hose Sue & Larry Gear and Maintenance Articles 0 01-02-2002 07:00 PM
